Hi all done a quick search and couldn't find anything to help me so thought I'd make quick thread.
Okay so I was replacing the rear calipers on my a3, removed one caliper to get the casting number to be sure to get the right ones, clampe d the flexi to stop air getting into the system and fluid getting out.
But being the c**t he is my brother needed some vice grips so took them off the car. The system ran dry of fluid and after replacing the calipers I now I cant get the brakes to bleed properly at all.
I've tried bleeding them the conventional way and now have vcds lite and have tried bleeding the abs to no luck (vcds won't work properly).
I've gotten a good amount of air out the system but still don't have any brakes tI'll my foot is on the floor and if I press it any harder then the wheels lock up and the car starts skidding. What am I doing wrong? What do I need to do? Also I'll attach a pic of vcds to show what I mean about it, the go box is greyed out not allowing me to select it.
Thabks In advance
Thabks In advance
