Badger5EM Tuning
Results 1 to 27 of 27
Like Tree2Likes
  • 1 Post By <tuffty/>
Thread: Timing
    A3 NICK's Avatar
    BOOOOOOOOOST!!!
    Aug 2012
    South East
    52
    Timing
    Hi all just fitted my new cambelt, done the whole sodding thing then realised the crank has gone one tooth past TDC Is this ok as its only advanced my timing by a small amount? This shouldn't cause any damage to valves should it? but will it affect the torque band? should I set it back to normal or is it ok to leave it as it is? car is an A3 98 1.8t agu
    Current Mods
    KO3s, TIP, Longlife custom Exhaust, 3inch Downpipe/Decat, FMIC, Forge 008p dv, VR6 Clutch/G60 Flywheel, Stage 1 Revo Map, Momo GTR Alloys.
    Waiting to fit
    Calibra 346cc injectors, JOM Coilovers and some bits and bobs.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,559
    Put it right... the end...
    <tuffty/>
    hoffmanvp3 likes this.
    A3 NICK's Avatar
    BOOOOOOOOOST!!!
    Aug 2012
    South East
    52
    Okie dokie, cheers <tuffty/>
    Current Mods
    Waiting to fit
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Some ones been using the Aus manual.....nah it`ll be alright mate
    A3 NICK's Avatar
    BOOOOOOOOOST!!!
    Aug 2012
    South East
    52
    Out of curiosity what affect would it have?
    Current Mods
    Waiting to fit
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,559
    Again. .. put it right...
    <tuffty/>
    Gops likes this.
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Worse case...piston hits the valve. All modern engines are interference fit motors
    A3 NICK's Avatar
    BOOOOOOOOOST!!!
    Aug 2012
    South East
    52
    Cheers hoffmanvp3 was just curious, will redo it tomorrow morning. Ran out of light this evening!
    Current Mods
    Waiting to fit
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    or could burn a valve as it`ll allow the combustion process to enter the exhaust manifold or up the intake manifold depending on how much you have advanced or retarded the timing
    A3 NICK's Avatar
    BOOOOOOOOOST!!!
    Aug 2012
    South East
    52
    Advanced by one tooth, left it all open so will only take a few to set it right again. Just hoping it doesn't decide to rain like today.
    Current Mods
    Waiting to fit
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Did you rotate the engine with this one tooth out?
    A3 NICK's Avatar
    BOOOOOOOOOST!!!
    Aug 2012
    South East
    52
    Nope, just noticed it didn't line up so called it a day and left it for the night.
    Current Mods
    Waiting to fit
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Well that's not so bad then. Good thing you noticed it then lol
    A3 NICK's Avatar
    BOOOOOOOOOST!!!
    Aug 2012
    South East
    52
    Damn annoying though! Oh well cam back off tomorrow and will all be fixed. Followed by a fun filled turbo change lol
    Current Mods
    Waiting to fit
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Try to take the slack outta the belt before pulling the pin as this will show you if the alignment is ok.
    Kinda hard to explain over the net
    Timing Belt replacement writeup with 61 pictures and 44 steps....>> - AudiWorld Forums
    Try this
    Oct 2012
    birmingham
    245
    as tuffty said put it right
    A3 NICK's Avatar
    BOOOOOOOOOST!!!
    Aug 2012
    South East
    52
    Cambelt all done and timed correctly now, Fitted my KO3s as well. Easy enough job just could have done with a bit more space. Quick question though, Under load the car has the slightest intermittent dip and gain in boost, as if the car cant get fuel in quick enough. Still got to wait a couple of weeks till my remap but just wondering if anyone has an explanation as to why this could be happening? Thanks
    Current Mods
    Waiting to fit
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Mine does that on gearchanges when pressing on, or when progressing from no throttle to wide throttle angles.
    Boost guage immediately jumps to 5psi, sits there for a moment, then swings round to 10psi.
    On mine, I'm fairly sure its simply because the map isnt dialled in for the turbo.
    TD5 Land Rover Defender build
    A3 NICK's Avatar
    BOOOOOOOOOST!!!
    Aug 2012
    South East
    52
    Must just be my map is not working with the new turbo, Feels like the ECU doesnt know what to do with the mass amount of air going in now! Hopefully the map will sort this out as the car runs fine when cruising and when power is eased on. Are you still waiting for yours to get mapped?
    Current Mods
    Waiting to fit
    "Stick a V8 in it!"
    15,370
    Mines been like this for about 2 years :P
    I really need to get my finger out and sort the mapping though!
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    Mine does this too. I blame the larger TIP as I don't have any other mods and haven't mapped it yet.
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,361
    be very careful driving it with the k03S and old ko3 map mate, it won't be fuelling correctly and could cause issues if you thrash it.
    A3 NICK's Avatar
    BOOOOOOOOOST!!!
    Aug 2012
    South East
    52
    Looks like sensible driving until remap day then will try and get my map day moved soon then hopefully will be back on the road properly
    Current Mods
    Waiting to fit
    A3 NICK's Avatar
    BOOOOOOOOOST!!!
    Aug 2012
    South East
    52
    Prawn could i just unplug the N75 and run of actuator pressure until its mapped? Just to keep everything in control.
    Current Mods
    Waiting to fit
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,361
    you sure could mate, that's the standard advice in this situation
    "Stick a V8 in it!"
    15,370
    You could yes.
    If its an AGU, i wouldnt be too worried though, the ECU just backs off the boost a bit to ensure the stock airflow targets are met.
    Driving sensibly until its mapped is obviously a good idea either way.
  28. #27
    A3 NICK's Avatar
    BOOOOOOOOOST!!!
    Aug 2012
    South East
    52
    Ok Cheers guys cant wait to get up to R-tech now and get it mapped!! Wonder how long i will be happy with a KO3s until i want more power and a huge turbo lol! I would get a stern one of these from the Mrs if that happens
    Current Mods
    Waiting to fit
  1. Most important car of all time
    By dbm in forum General Chat
    Last Post: 12th May 2003, 09:40
  2. It's that time of year again - insurance quotes?
    By ColinM in forum General Chat
    Last Post: 14th April 2003, 17:03
  3. In gear acceleration times
    By Simon in forum General Technical / How To
    Last Post: 10th April 2003, 20:37
  4. time for a new post lol!!!
    By CARACTERE007 in forum A2 forum
    Last Post: 22nd January 2003, 18:39
