EM TuningMonster Motorsport
    miniturhero's Avatar
    Aug 2013
    57
    limp mode I think ? very low boost? help please
    Hi everyone I will explain the problems I have
    My 2002 s3 as ive mentioned in previous posts boosts around 20psi im unsure if its been remapped as havent got it cheacked but boost would suggest it has. It has been boosting that since ive had it ( around 2 month) with no problems but this morning my engine management light came on and boost went down to 6-8 psi I suspect this is limp mode but the only code I get it P1296 which I think is just my thermostat but ive had that for around a week but due to working away I havent had the time to fix. Also since last week my clutch has been slipping when under boost is this related to the limp mode ? I know from searching the forum that the clutch is probably due to a sticky slave but wondered if they have any relation between my boost problem? I will be so grateful for any ideas or advice as this is doing my head in.
    Thank you
    Dino
    Drewvic's Avatar
    Nov 2013
    North yorkshire
    203
    have you checked for boost leaks mate
    I have had similar problems and found a splt hose and also the n75 was playing up
  1. Audi a3 2.0 tdi going into limp mode at high speed can anyone help
    By Keith31harding in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th October 2013, 11:42
  2. Very noisy A3 - help please
    By nvc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th October 2009, 22:37
  3. Very low boost??
    By Speedy Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2009, 17:54
  4. limp mode due to inlet manifold pressure HELP !!!
    By sahk in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th January 2005, 19:39
