Results 1 to 20 of 20
    Nov 2013
    15
    convenience module wiring diagram needed
    Hi , does anyone have a wiring diagram for the convenience module, I am looking for the wire that sends the open/close signal from the doorlocks to the ccm.
    Nov 2013
    15
    I trying to install a aftermarket remote locking on my sons car and have a wiring diagram for the kit, but need to know what wires on the central locking pump I have to connect to.
    Someone please assist me... pretty please?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    I'll take a look at the wiring diagram when I get home and see what I can tell.
    Would it be worth bolting in a standard Audi remote central locking unit like Jay A3 did?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Nov 2013
    15
    Maybe in the future, but for now this kit is quite handy as uses flip type key the same as audi use.
    But we will keep a eye out for a audi one with keys.
    Thank you for your help and If you could tell me what wire I need to connect to, that would be great
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    here's for when i installed puddle lights (same switch for door open/close)
    puddle light fitting guide for pre-facelift
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Nov 2013
    15
    Thanks, altho looking for the wire that sends the lock/unlock signal that triggers the central locking pump.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    The central locking done via the remote or lock in a door is all done with in the central locking pump.
    That whole thing does everything.
    I will take a look tomorrow for you but thinking on it, I don't think there is a separate cable with the lock or unlock signal.
    Unless its sent to the interior light module or something.
    Nov 2013
    15
    Thanks mate, and yep I think 1 wire too, can set it to work with 1 or 2 wires, just need to know which wire/wires lol.i looked at a a4wiring diagram, but they have a lock and unlock cable? Cant find a a3 one anywhere
    Nov 2013
    15
    here are the full wiring instructions with the unit, I am going by figure f for negative pneumatic for the a3
    A3 TQS
    Jul 2013
    Devon
    171
    Nov 2013
    15
    Thanks, I did but I cant see a few of the wires on my car that was mentioned in that thread, maybe they changed it a little from 96-98?
    Nov 2013
    15
    Looking again, on the instructions on the other thread, there is a open and close wire?. If I followed that, what colour wire would I connect on my unit, as looking at the diagrams, on negative trigger there is only a opening signal connection?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    I think its something like this.
    Opening - White to Brown plug - Grey Cable
    Closing - White/black to Black Plug - Red/Brown
    Nov 2013
    15
    Thanks, I tried and got it kind of working, I pressed lock and instead it unlocks car, but nothing happens when I press lock. Also had problems with stupid Scotchblocks not making proper connections, so may solder tomorrow, altho need to work out what wires I need to connect for the other switch circuit, can only think its needs another ground?.
    Nov 2013
    15
    Also strangely, since I did it all, and ive disconnected the new module until tomorrow, I have noticed the little red leds next to the door pins no longer flash when the car is locked.
    Anyone have any idea why?
    Nov 2013
    15
    I also seem to have lost interior lights in the car and boot, so assuming I've blown a fuse somewhere?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    This is the joys of aftermarket kits.
    Its a lot of faffing and messing a bout and by the time you got it all done the OEM kit could have been in and coded.
    I'm not sure why its stopped.
    Some thing could have popped when the unit was plugged in.
    But I don't know, sorry.
    Nov 2013
    15
    True altho I dont have vcds etc, and altho I have a obd ii cable but it won't recognise the audi in any app, it can't find the ecu, yet on my wifes fiesta it finds it, as well as in my car. Altho I think its because its a 96 a3, and isnt obd ii compliant? It does however have a obd port.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Quote Originally Posted by gavin.m View Post
    Where you based?
    VCDS is not a problem if you got a friendly VCDS owner near you or talk to @udi A3, he helped Jay A3 doing exactly what you're trying to do.
    Nov 2013
    15
    Hi, I am in the south west in wiltshire. If anyone down this way could help with vcds, that would be great, but isnt this audi too old, as I dont think its obd compliant
  1. electrics problems/ wiring diagram needed
    By moggie93 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th July 2012, 13:06
  2. Audi A4 Cab Central Electronics Control Module Wiring diagram
    By g12 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 21st June 2012, 22:01
  3. Help needed with an electrical issue. (Wiring Diagram needed)
    By Wiganer in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th October 2011, 10:48
  4. Replies: 0
    Last Post: 4th May 2011, 16:58
  5. A4 1.8Turbo 2002 Instrument cluster wiring diagram Needed,
    By Ciaran in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th January 2010, 22:28
