Chris NottMonster Motorsport
Results 1 to 23 of 23
    Feb 2013
    17
    Knock driving me crazy!
    Hi all. Been a member for a few months now and have never felt the need to post for help but I am well and truly stumped.
    I have got a slight knock coming from the front drivers side. It not a loud knock and only happens while going over uneven road. I can hear it while going slow but obviously the faster I go the louder the engine gets so I no longer hear it. I have replaced pretty much everything I can think of and I don't know what to do next lol. Thank you for any advice you can give.
    1998 a3 1.8t AGU
    Replaced both wishbones
    Replaced both wishbones bushes to poly
    Replaced drop link arms
    Replaced strut top mounts and bearings
    Replaced anti roll bar bushes
    Replaced both drive shafts
    Additional mods
    Oil catch can
    K04-001
    2.5 inch turbo back exhaust
    Forge tip
    Forge recirc dv
    Remap as soon as this knocking noise is sorted and fmic installed
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    886
    Add Vex182 on Facebook
    Brake pads rattle? My rear ones were doing it for months before I found it.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Mar 2012
    Aberdeenshire
    10
    Loose arch liner or belly pan?
    13.015@110 mph on a ko3s
    BEACHBUGGYTURBO
    DMC Performance
    Feb 2013
    17
    Brake discs and pads been done. And there is no plastic belly pan on it. It sounds like a dull metal on metal. Its not far off the same sound as a wishbone bush that has gone bad?
    Oct 2013
    I recently bought a 2002 S3 and had the same knock over rough ground at low speeds.
    After changing a few bits and pieces I discovered that the drivers side front shock was the culprit. Not only did it have no rebound left in it, the damper was rattling about in the shock body.
    A pair of new dampers later and the jobs a good 'un.
    Cheers.
    Feb 2013
    17
    Thanks mate. I will check that out when I get back from lodging. Cheers
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,567
    Track rod and ends?
    Feb 2013
    17
    I have checked them and they are fine
    Grant-s3's Avatar
    Nogaro Blue
    Jun 2013
    Glasgow
    69
    Have a look inside the engine bay incase anything is loose and knocking about. Then jack it up, remove the wheel and gently tap away with a rubber hammer and listen.
    Oct 2013
    Carlisle
    30
    Wheel bearings?
    Feb 2013
    17
    I checked the wheel bearings last weekend and they are ok
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,639
    I know this sounds obvious.. But is your wheel tight? Mine was slightly loose and I had exactly the same symptoms.. I have no idea how it came loose but I guess it worked its way loose somehow..
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,639
    Ow and make sure the DV isn't hitting the strut brace.. Happened to me and drove me completely insane for months!!!
    Feb 2013
    17
    I haven't got a strut brace mate. Dv not hitting anything. All wheels are tight. I didn't change all these parts in one go so the wheels have been on and off numerous amount of times lol
    Oct 2005
    bristol, uk
    757
    Cv boot? I had this before
    Does it happen when turning at low speed?
    Try putting it on full lock and have a look to see if cv boot is split, you'll probably see some gunk
    Researching and potentially looking for a nice S4 B6
    Previous cars: Modded Toyota Celica 1.8 Vvtli, modded mk1 TT, standard mkv r32 dsg
    Current: family wagon diesel
    Feb 2013
    17
    Its not a cv boot mate. I have replaced both drive shafts with new boots. It happens when going straight and when turning
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,567
    Quote Originally Posted by MyCarling View Post
    I checked mine, and they were fine too! but on a Hunters 4 wheel alignment machine, it detected 0.1mm play on the passenger side steering rod!! Changed to a new one, and knocking disappeared.
    Feb 2006
    Lincolnshire
    721
    I would second what jojo said, my car was making very similar recently. All new dampers/springs/drop links/top mounts and roll bar bushes which I thought would sort it, but to no avail.
    I replaced the track rods and ball joints more out of desperation than anything, and the noise disappeared. The stuff on there had sailed through the MOT a few weeks ago too, but must have been some play in there somewhere.
    Not sure ultimately whether it was the track rod ends or ball joints, but I did notice a metal rattle sound when I tapped the steering rack arm on one side with a rubber mallet. When I do the same post change, there isn't a sound.
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
    Feb 2013
    17
    I will replace them then when I get paid next... I had just persuaded the wife to let me fork out on new shockers and coilovers lol
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    440
    I have this same knocking, also an A3 8L 1.8t. It has starting happening ever since I wound the coilovers down a couple of CM's. Let me know how you get on
    Progress Thread - http://www.audi-sport.net/vb/a3-s3-f...thread%5D.html
    A3 8L 1.8T AGU BLACK
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    440
    Also, when going very slowly and lightly putting foot on the brake, can you feel it through the brake pedal?
    Feb 2013
    17
    I dont feel it through the brake pedal mate
    RobinJI's Avatar
    Jul 2012
    Chard, Somerset
    147
    Yep, I'd second track rods/ends, I take it you did the lower ball joints along with the wishbones? Failing that it could be worth adjusting the steering rack.
    1.8 20v turbo converted '88 Scirocco - ASN Build Thread
  1. s3 8l facelift driving me crazy! ABS and ESP lights
    By baconsworld in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2013, 07:49
  2. knock high voltages, driving me crazy
    By big nog in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2013, 17:03
  3. A3 2.0TDI low poor sh*t MPG.. driving me crazy some 1help!!
    By AntonTDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th May 2012, 19:27
  4. Squeaks drive me crazy!
    By alecblack in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th September 2006, 18:42
  5. HELP!! Alarm driving me crazy!!!
    By mikeA2B in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th December 2004, 19:14
