Volks AutosAH Fabrications
    danej's Avatar
    Jan 2006
    Aberystwyth, Wales
    49
    Cutting out/Stalling
    Hey guys,
    My 1.8t a3 sometimes stalls or cuts out on me when i come to a stop or dip the clutch, its as if the revs are dropping too quick. I have recently fitted a dump valve (which is comming off soon, bloody annoying!!) but this happened a few times before i fitted it!
    Ive had it checked out and found a fault with the wastegate release valve (I think thats what he said!)
    Has anyone experienced this problem? [img]/ubbthreads/images/graemlins/confused.gif[/img]
    S3PEG's Avatar
    Bristol
    99
    Did you ever get to the bottom of this? Thanks.
    S3Peg
    Black S3, APR Chip, EBC Brakes, 18" RSTT's.
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,985
    id put my money on the crank sensor..... i had exactly the same, vag it first though
    Xbox 360 gamer ID : Timffy
    Black FZ6 - Turbo car 'slapper'
    Oct 2009
    178
    just had same problem with my s3, was the MAF
    S3KO4's Avatar
    Aug 2009
    London
    850
    I was going to say it is maf u could also check by removing the connector
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,985
    yup agreed,unplug and see if it still does it..... although i dont recall the MAF causing such drastic problems
