Results 1 to 10 of 10
Thread: wet boot grrrrr
    Mar 2013
    Chelmsford , Essex .
    198
    wet boot grrrrr
    hi peeps ,
    ive recently noticed my car steaming up so set about hunting a leak !
    found the spare wheel well full of water !
    now its never done this before and before you all tell me it's the washer jet pipe , i don't use my rear wash or wipe
    the only thing thats changed since this started is i have fitted facelift rear lights off my mrs written off facelift TQS .
    i used the foam sealing pads from her lights and my bulb holders .
    so my question id what have i done wrong ?
    baz
    1999 Silver 8L A3 1.8t sport (AGU) currently undergoing rolling modification
    pipercross panel , bosch super 4's , poly bushed front end , yellow dogbone , self refurbed 16" speedlines , ambient lighting.............TBC
    http://www.audi-sport.net/vb/a3-s3-f...ts-thread.html
    Mar 2013
    Quote Originally Posted by basil brush View Post
    hi peeps ,
    baz
    hey I'm not sure if I have the right answer for you hopefully someone will be along soon to correct me if I'm wrong
    but I had the same problem with my Lupo Gti and is a known fault on the lupo Gti . Where there is a rubber bung/ seal underneath the spare wheel hole and it perishes and start to allow water through . I only worked it out after I found a spare wheel well soaking wet . It only happened when it rained a lot or was cold and damp outside. It's just a idea I hope this helps
    nick
    Mar 2013
    198
    hi , thanks for the reply but it isnt a bung in the floor as the wheel well was holding water , if there was a leak it would also run out aswell as in , plus the boot carpet was wet and the upper part of the boot floor !
    thanks anyway
    baz
    Scotsman86's Avatar
    Jun 2011
    Glasgow/Germany
    16
    Have you checked the rubber seal surrounding the edges of the boot...could just be a simple tear in the rubber
    Mar 2013
    198
    Yep checked that
    All is ok with the boot seal !
    baz
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
    Ariel base?
    Mar 2013
    198
    No I don't think so !
    Im guessing that would make the head lining wet ?
    Im convinced it's related to the new facelift lights in some way but not sure how !
    are the foam and rubber seals the same on pre and facelift lights ?
    Baz
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    Itll be one of 3 things, I know as I had this for 2 years.
    It'll either be
    Aerial base will be leaking (replace or silicone it)
    The boot hinges where it connects to the roof, the plastic covers trap water and runs down (remove the plastic and douse in silicone)
    The rear lights are leaking, remove and douse the foam area of the lights with silicone.
    I guarantee it'll be 1 of the 3
    Feb 2012
    Rutland
    131
    Dani is right. I silicone'd the aerial base and hinges last weekend on his advice and I think mines drying out. Check your rear seat belts - they wet too?
    2001 AMK S3 in Goodwood Green
    Mar 2013
    198
    Will get out and have a look tomorrow
    baz
  1. Wet boot trim - A6 Avant...
    By amimmortal in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th December 2009, 09:37
  2. Boot Spoiler
    By stelios24 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd October 2003, 16:12
  3. ESP over speed humps, but only in the wet?
    By elgjc3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd May 2003, 13:55
  4. Who's had the wet exhaust rattle modification?
    By JaGermanCar in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2003, 10:23
  5. Leaky boot
    By skoller in forum Classic Audi Forum
    Last Post: 20th January 2003, 23:32
