Volks AutosEM Tuning
    Jul 2013
    134
    Lazy Xenon headlight
    I've read loads of posts about headlight adjustment.... Once i switch my lights on they are at the correct level but after being on for 5+ minutes the passenger side headlight drops to the lowest setting. This is a replacement headlight and has never been set to the "home" position whilst in this car... Is this all that's required for it to stay where I need it?
    mattyboy199's Avatar
    Nov 2005
    UK
    1,678
    I have a similar issue, i recon both headlight sit low.
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    If it gets to the right place and then one of them drops it's probably a dodgy adjuster motor on that side.
    You can buy new adjusters but if you take them apart you can clean the contacts and get a bit more life out of them - in my experience anyway.
    If you're not VERY careful removing and re-inserting the adjuster motors you will break the clips that the adjuster ball goes in and cause yourself a royal head ache replacing the clips.
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Jul 2013
    134
    I've already changed the clip which ye had broken to a new metal one. I will try the vcds trick tonite.
    Nov 2005
    UK
    1,678
    whats the VCDS trick ?
    wanted for 8L S3:
    Milltek system
    Jul 2013
    134
  1. looking for xenon headlight conversion
    By ray_nsm in forum The Welcome Section
    Last Post: 12th September 2004, 20:44
  2. xenon headlights
    By adamgroves in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2004, 23:52
  3. wandering xenon headlight - any ideas whats wrong
    By dunk in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th December 2003, 13:10
  4. Xenon Headlights - 7 fix for a 680 headlight!
    By Patrick in forum Classic Audi Forum
    Last Post: 12th October 2003, 17:16
  5. Xenon Headlights
    By wascal in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2003, 21:43
