EM TuningAH Fabrications
Like Tree1Likes
  • 1 Post By Westy
Thread: Battery sign/ brake sign/ abs light on??
    Oct 2012
    42
    Hi guys..
    1.8t has been parked up for 3 days... Started it and after 10 mins the brake sign came up on dash in red and so did the abs light with three beeps... Then the yellow battery sumbol appeared too... Car still drives fine but have also noticed the all dials stopped working!? Lights still work.. Car still starts abd drives fine but these things keep appearing and all dials dont work!
    now do i need a new battery or alternator? Battery is a tad small so cud be battery? Anyone else had this problem?
    thanks
    aaron
    ps started it again today and same problems.. But still starts and drives fine.
    Oct 2012
    42
    Okaay guys its still doin this.. Dials only work when drving like 5-10 mph anythn over that they stop working..
    Yellow battery symbol keeps appearing on display along with brake warning and abs light is on too... Yet the car starts
    and drives absolutly fine!!??
    any help? Maybe bad earth?
    Oct 2012
    42
    Okay further update... Jus took it for a drive to mates... Was doin the same... Parked it up for 2 hours..
    drove it home n everything seems fine now.. Battery symbol brake symbol n abs lights now gone off n dials are working..
    so my guess is a bad earth triggering this elec fault????
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Alternator could be on its way out. Mine started off with the battery light (which means the batteries charge is low) then 1 day the car wouldn't start. I jumped it and got it home but on the way home the ESP light came on and the general performance of the car was shocking. I had misfires too and when I scanned the car with VCDS there was cam timing errors and all sorts! All issues went when I fitted a brand new alternator.
    If you do a search for my thread (will have alternator in the title) there's a YouTube video in there that shows you how to check the alternator is healthy.
    Aaron1.8t likes this.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  1. Brake And ABS Lights On
    By rt05492 in forum VCDS (formerly VAG-COM) forum
    Last Post: 4th March 2010, 20:31
  2. squeeking brakes and ABS/ESP light
    By glen_jai in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2009, 19:12
  3. brake binding problem / abs light problem
    By brendan in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th November 2008, 20:24
  4. Brake system warning light - ABS related?
    By bantam1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2008, 03:16
  5. Rear brakes & ABS light
    By apupi in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th May 2007, 09:12
