Volks AutosAH Fabrications
Thread: Juddering boost
    Feb 2012
    Rutland
    131
    Juddering boost
    Hi all,
    In short; low revs and high load = juddery boost delivery. Once it gets to higher revs its fine. Initial thoughts are N75 a little dodgy? Definitely not missing so doubt it's coil pack or spark related. Anyone else experienced this?
    Haven't got access to vcds but will invest in a cable now as a priority.
    Cheers,
    Dan
    2001 AMK S3 in Goodwood Green
    Jul 2011
    wiltshire
    121
    Sounds like a problem I'm having chucked it on vcds and it came up with faulty lambda sensor, replaced sensor with genuine audi part and it still juddereds under acceleration occasionally yet no fault codes??
    Feb 2012
    Rutland
    131
    I replaced lambda sensors in march, had new coil packs about 18 months ago, new plugs in feb.... Still haven't bought vcds though so haven't got any closer....
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    I've had this three times on different cars.
    First time, it was a split hose off the inlet manifold.
    Second time it was a bad coil pack.
    Third time it was a bad coil pack.
    TD5 Land Rover Defender build
  1. S3 Slight Judder As Boost is Coming On
    By Cheese in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st January 2012, 11:26
  2. HELP - S3 Couple of issues (juddering when on boost & headlight angle)
    By gman1981 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2010, 11:38
  3. Judder and Boost Question
    By adam8747 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2010, 11:20
  4. Judder on max boost
    By 1animal1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2009, 08:36
  5. Steering Judder
    By Drystone in forum Other Brands & Models
    Last Post: 6th January 2003, 17:28
