Chris NottBadger5
    Oct 2013
    Carlisle
    30
    A3 very strange noises
    Hi all, every time I get in my a3 (1.6 engine code bfq. 76k miles 52' plate). Soon as I press the accelerator I hear something like bubbles going through some pipes! Soon as I press my foot down it sounds like something blows all the bubbles away. It does this once for about a second or two every time the car has sat for a while. Coolant level looks fine. Cambelt and water pump change at 75k (only 1000miles) Please bear in mind this has always done this even before water pump change) The temp on the gauge is fine at 90. No eml on.... It sounds to me like its air in the coolant system and when I put my foot down the water pump spins faster therefor pushes the bubbles away.
    matt blowen's Avatar
    Jul 2013
    staffordshire
    140
    Add matt blowen on Facebook
    I know it sounds strange but it your PAS fluid low?
    Oct 2013
    Carlisle
    30
    I'll take a look, worth checking thanks
    May 2013
    27
    I get a similar noise to what you are describing, mine seems to be linked to the heaters though although now you mention it I do only hear it on idle after a good blast, I'm going to have to listen more carefully when driving now. Does yours seem to change at all with the heaters/aircon on or off?
    May 2013
    27
    Just read this ticketyboo, a couple of posts down might interest you (link below may not work, I've got no clue how to insert links tbh)
    HTML Code:
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/202849-whats.html
  1. Strange Noise when reversing
    By Nimo in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th December 2009, 18:40
  2. Strange Noise - Sounds like BOV
    By godwine in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th May 2004, 22:52
  3. This is very strange.......
    By tobybutler in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st April 2004, 00:26
  4. Strange noise..
    By s8n in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2003, 00:44
  5. Strange noise - anybody got a clue !?
    By audi_girl in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2003, 16:52
