AH FabricationsBadger5
    Oct 2013
    Carlisle
    30
    Audi a3 fuel filter
    Hi, I have a 1.6 52 plate a3 engine code bfq. It's never been serviced in I imagine over 5 years. I have changed pollen filter. Air filter. Full oil change and filter. Had the manifold off to change the spark plugs (nightmare) However need to change fuel filter. Where is this located and how easy/hard is this to do. I am a plumber, so I'd say I'm more familiar with push fit fittings then a mechanic. I use fittings with gas, kerosene oil, LPG etc so don't worry I'm not silly. I know being a plumber is no mechanic. But cars are just like boilers once you realise what part makes what part work, be carefull with everything you touch, and using the correct sealants etc I know all this.... Just need a little guidance for changing it and it's location. Thanks
    samurai's Avatar
    Nov 2013
    Slovenia
    68
    You have to go under the car and where is a tank there is the fuel filter - under by rear right wheel. No art to change that filter, all you need a screwdriver or key 10 (can not remember).You just need to watch filter properly install, because filter have flow direction (you have arrow on the filter- in / out) - thats it
    it looks like this:
    Oct 2013
    Carlisle
    30
    Thanks very much!
  1. Audi s3 fuel filter location?
    By Hanz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th February 2012, 18:32
  2. which fuel filter: 2002 audi a4 1.8t quattro
    By axmarque in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd January 2011, 19:13
  3. Fuel Filter
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2007, 12:08
