ticketyboo90
Hi, I have a 1.6 52 plate a3 engine code bfq. It's never been serviced in I imagine over 5 years. I have changed pollen filter. Air filter. Full oil change and filter. Had the manifold off to change the spark plugs (nightmare) However need to change fuel filter. Where is this located and how easy/hard is this to do. I am a plumber, so I'd say I'm more familiar with push fit fittings then a mechanic. I use fittings with gas, kerosene oil, LPG etc so don't worry I'm not silly. I know being a plumber is no mechanic. But cars are just like boilers once you realise what part makes what part work, be carefull with everything you touch, and using the correct sealants etc I know all this.... Just need a little guidance for changing it and it's location. Thanks
