Chris NottBadger5
    Oct 2013
    fan control module
    where do i find the fan control module on s3 8l.
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Just below the battery. IIRC It's a bit of a pig to get to - easier if you remove the battery and battery base. Be careful not to damage any of the plugs/connectors they can be a bit stuck.
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
  1. 18354 - Control Module 1 for Coolant Fan: Defective
    By Digzz in forum VCDS (formerly VAG-COM) forum
    Last Post: 21st May 2011, 08:41
  2. Can Airbag Control Module be repaired rather than replaced?
    By Rhunster in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2005, 15:29
  3. HELP! ignition control module!
    By imported_tristram in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2004, 21:55
  4. Fan Control Illumination
    By OMT in forum A8/S8 forum
    Last Post: 19th June 2004, 00:12
  5. removing climate control module
    By DrX in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th September 2003, 08:30
