Volks AutosSky Insurance
Results 1 to 1 of 1
Like Tree2Likes
  • 2 Post By VAG-Slag
Thread: Squeaky window fix...
    Jul 2011
    Berkshire, Surry, Hampshire tri-intersect
    413
    Right, so over the summer my drivers side window started squeaking in the most annoying fashion possible and has only got worse since... Tried squirting a bit of silicone spray round the seals but this did nothing. Upon doing a search there are a few threads with people describing the same problem all with a list of people also compiling about the same problem but ultimately no one with any solutions. So I thought I'd have a stab my self!
    Firstly, here's a short vid of exactly how annoying the noise was:
    !WARNING! Some viewers may find these noises distressing!
    See!? . .
    Right, and here's how I fixed it... First, remove the door card. To do this remove the hidden screw in the door puller, slip out the insert in the handle and remove the 2 screws behind it. Remove the 2 screws either end at the top and then lift the door card out. Detach all the cables and etc a put some where safe... You will also have to remove the window switch so you can actually operate the window!
    Now, see that little blue runner I zoom in on in the video? There's a wire that runs up and down with that which goes round a pulley at the top just behind the door pin... Cake the wire in a thick grease (I actually uses vaseline) when the window is up and down, also take the inside window seal out to allow access to this pulley and use a scraper (knife will do) to smear grease into this pulley while going up and down with the window. Wind the window fully up and down a few times and that should be the end of your squeaky window woes!
    Hope this helps as there seemed to be quite a few people with the same problem!
    voorhees and s3dave like this.
  1. Faulty S3 Electric Window Fix
    By HTC in forum A3/S3 Forum (8L Chassis)
    Last Post: 2 Days Ago, 17:39
  2. electric window fix
    By michaespirou63 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2012, 19:57
  3. Dead Battery Following Electirc Window Fix
    By A3Tomlin in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2011, 16:13
  4. Squeaky windows- s3
    By gabrialboy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th January 2010, 06:57
  5. S3 window fix - where to get the parts in 24hr?
    By Ciaranl in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th June 2009, 16:32
