Volks AutosAH Fabrications
    Oct 2012
    Aberdeenshire
    26
    Electrical problems
    Hi guys, trying to get my s3 back on the road but it's developed some electrical problems, the dip beam xenons and tail/brake lights aren't working but the full beam and side lights are, could it be a relay or something along that lines, I've checked the bulbs and the fuses so not sure what else to check, thanks, Gary.
    Oct 2012
    Aberdeenshire
    26
    Having removed the headlights i checked the plug that goes into the back of the headlight and it turns out the live feed to the ballast is getting no power but the full beam and sidelight wire is showing 14v, could it be a fault bulb failure module? Any ideas or help would be much appreciate, thanks
  1. Electric problem - HEEELLLP!!
    By mordz in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th March 2007, 20:33
  2. Electrical problem (Number plate lights)
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th April 2006, 14:02
  3. Dreaded electrical problems!
    By Vorshprungdork in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2005, 20:34
  4. Electrical Problems
    By pmorgan in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 27th September 2005, 21:33
  5. ELECTRICAL PROBLEM ON A6 1.9 TDI 1998 >
    By imported_terry2wheels in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 26th August 2004, 19:29
