Results 1 to 10 of 10
Like Tree3Likes
  • 3 Post By jojo
Thread: what power should i expect
    May 2012
    Barry, Vale of Glamorgan, United Kingdom
    55
    Hi all.
    I have a 1999 s3 8l. It has badger 5 tip, s2000 airfilter, n249 delete, and a revo re map.
    Im having the car rolling road run at the end of the month. What sort of power do you guys think I should get?
    Thanks all.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,391
    250hp
    TD5 Land Rover Defender build
    chaz20vt's Avatar
    Aug 2012
    425
    Mine was rolling roaded at 252bhp i don't have a badger 5 tip though but do have a 3" cat back
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Hugely subject to condition of engine/turbo/pipework etc... make sure you are using decent fuel (v-power)... also depends what revo settings are in there... some people just turn everything up to max without checking... you can actually get less power from doing it that way..
    <tuffty/>
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,613
    Quote Originally Posted by s3welshy View Post
    Hi all.
    Thanks all.
    Depends on whose dyno you go on?
    badger5, voorhees and Revo Steve-W like this.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    899
    Add Vex182 on Facebook
    My car is a similar spec and is running 254bhp.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,924
    I got 280bhp with less mods on some happy dyno.
    If I were you I would try and lend an sps switch to turn it back to stock,try it then and go from there for a better reading.
    JoeeS3's Avatar
    Apr 2013
    Cardiff
    369
    Follow JoeeS3 On Twitter Visit JoeeS3's Instagram Channel
    If you need an sps I have one welshy. Where are you getting it dyno'd by the way?
    i'm not a genius...i'm a learner
    Adam P's Avatar
    May 2012
    Southampton
    396
    I would guestimate around the 250bhp mark like the others have said, however it would be interesting to see you results and chart if you could post them up afterwards?
    Adam
    2001 Audi S3 8L Ming Blue - Rebuild Complete
    Apr 2011
    Dublin, Ireland
    621
    240-260hp, depending on condition of engine and of course dyno lottery.
    B5 v1 Tip, B5 Exhaust Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket, Devils Own Water Meth Kit, Forge baffled sump.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, R32 ARB's, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear, Vibratechnics Engine Mounts.
  1. what power should i be making
    By jonno123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th November 2012, 10:06
  2. What MPG should I expect ?
    By H2o-uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th February 2009, 09:18
  3. What should I expect from the 1.9tdi (130) CVT Auto?
    By amimmortal in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 3rd February 2009, 12:15
  4. What price should i expect for my car?
    By A4 TC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st February 2008, 21:13
  5. What should I expect to get?
    By Mandala in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th February 2007, 19:06
