Sky InsuranceVolks Autos
Results 1 to 13 of 13
    A3 NICK's Avatar
    BOOOOOOOOOST!!!
    Aug 2012
    South East
    52
    Vauxhall C20LET 2.0L CalibraTurbo injectors
    Hi All, Just have a quick question about some injectors i have got. I have got a set of 349cc Vauxhall C20LET 2.0L CalibraTurbo injectors (Yellow) When i called up Rtech these are the ones they told me to get for stage 2 on my KO3s. Now will these just be a direct replacment or will i need adapters for them to fit? And would it be worthwhile upgrading my fuel pump as well?
    Thanks! (Included a picture of them just to make sure they are correct)
    Current Mods
    KO3s, TIP, Longlife custom Exhaust, 3inch Downpipe/Decat, FMIC, Forge 008p dv, VR6 Clutch/G60 Flywheel, Stage 1 Revo Map, Momo GTR Alloys.
    Waiting to fit
    Calibra 346cc injectors, JOM Coilovers and some bits and bobs.
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    They look like the ones I have. Might be worth picking up a new set of o-rings and if you have access to an ultra sonic bath/cleaner always worth doing while it's out.
    You got a vr6 maf housing?
    <Jay A3 build thread>
    241bhp K03s - R Tech
    A3 NICK's Avatar
    BOOOOOOOOOST!!!
    Aug 2012
    South East
    52
    Cheers Jay A3 so they will just fit straight in? ok will pick a new set of O rings up from vauxhall. I dont know anyone with an ultra sonic cleaner, anyone you can recommend? I have a 3inch Aluminium MAF housing but was told that it would not be needed.
    Current Mods
    Waiting to fit
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    Since your looking for yellow tops yours is an agu engine?
    For stage 2 I could stay with the standard injectors and maf but would only see around 220bhp as these components would max out. Rtech said change the maf and injectors and I would see more which I did.
    Amazon or eBay sell these cleaners for £15-£30
    A3 NICK's Avatar
    BOOOOOOOOOST!!!
    Aug 2012
    South East
    52
    Yeah its an AGU, so i should stick the new MAF housing on as well as the injectors for the best results? I will have a look on ebay for some injector cleaning stuff. I would ideally like to see anything above 230bhp from the map, Hopefully i can achieve that.
    Current Mods
    Waiting to fit
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    Rtech said not to install the maf or injectors till your there so just collect the parts. If everything is running well with no faults you should a good figure. I'm at 240bhp with the oversize tip and BBT 10psi actuator. Did get to 260bhp on one run but niki didn't think it was safe running that hot.
    What spec you got?
    A3 NICK's Avatar
    BOOOOOOOOOST!!!
    Aug 2012
    South East
    52
    Nice figures! Stage 1 i made 190bhp and 235Ftlbs with a milltek catback, K&N Filter and forge 008p dv on a KO3. I now have:
    3inch downpipe with decat
    Custom longlife exhaust
    Turborevs fmic
    VR6 clutch & G60 Flywheel
    KO3s
    Creation motosprts TIP, Will get an oversized TIP when i can.
    349cc Injectors
    3inch Maf Housing
    Drilled and grooved Mtech Discs with EBC pads
    JOM coilovers to go on after the map along with my MOMO gtr Alloys.
    Current Mods
    Waiting to fit
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    Ah decent setup apart from the tip.
    Reason why I changed from CM tip to sfs one
    If you can I would change it before you go rtech...
    A3 NICK's Avatar
    BOOOOOOOOOST!!!
    Aug 2012
    South East
    52
    It is a mahooosive difference!! How much did that set you back? Dont suppose you know anyone who has one laying around for sale on the cheap
    Current Mods
    Waiting to fit
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    Set me back about £160 direct from sfs. But if you speck to rtech I'm sure they have a batch at the moment for £100 a piece approx.
    A3 NICK's Avatar
    BOOOOOOOOOST!!!
    Aug 2012
    South East
    52
    Awesome will have to ask when im up there! So you reckon with that set up i should see ok figures even with the sh***y TIP? Also changing the cambelt and water pump while im doing the turbo. Need to get hold of VAG COM before ideally as would like to see if its running any faults before i take the drive up to R-Tech!
    Current Mods
    Waiting to fit
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    If your car is in good condition with injectors and maf you should see the better side of 220bhp
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,906
    Visit 16Klappe's Instagram Channel
    You'll get 230bhp from a GOOD AGU and K03s without ****ing about with injectors.
    Niki knows this.
    I quite often say I'm going to do things.
    Then never do them.
  1. uprated sparks and injectors?
    By cyuen in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2004, 08:58
  2. Injectors
    By Ryanc in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th March 2004, 18:38
  3. S3 injector flow rate/max HP
    By excursion in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2003, 11:43
  4. Injectors
    By AL_B in forum Diesel forum
    Last Post: 27th August 2003, 16:26
  5. I need the part # for 310cc injector..please
    By austurbo in forum Tuning
    Last Post: 1st August 2003, 11:04
