Badger5Sky Insurance
Results 1 to 26 of 26
Like Tree1Likes
  • 1 Post By seafar99
Thread: A3 8l 1.8t thermostat location
    Nov 2011
    37
    Is this the correct location for the thermostat?
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    More or less lol
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    See the 6 bolts on the left on the painted side?
    2 on top, 2 in the middle and 2 on the bottom.....well the thermostat housing is to the right of the 2 top bolts, directly right of the water pump housing
    hope that helped
    Nov 2011
    37
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    If your still stuck then post back and ill see if i can find the guide i used when i changed mine
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    Nov 2011
    37
    Sure,fire away if you can find it,information most welcome.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    I found it:
    Thermostat replacement procedure..>> - AudiWorld Forums
    But i think its been so long the picture have stopped working
    Also buy yourself a new dipstick tube as the one you have is going to break
    Nov 2011
    37
    Thanks again, stat and oil guide tube are inbound.
    epox's Avatar
    Oct 2012
    Glasgow
    589
    A3 T had saved the pics so here goes,
    you can undo the housing bolts with a 10mm socket and small ratchet did it at the weekend no extension bars required.
    these pics are from a tt but the almost the same as my s3
    Well, here it is: I'm not going to say it is simple, but it actualy is. All the procedure should take 15 to 30 minutes,
    Here are the tools you will need to do this: 3/8" ratchet, as many extensions as you can get (about 24"), a 10mm short socket, 10mm box end (or long socket), flex joint , 5mm allen wrench or socket, a magnetic pickup (or needle nose pliers) and a channelock.
    We will asume the engine covers are removed, NEGATIVE post of the battery removed (check radio code first!) and of course, car IS cool, no pressure. Also, a clean engine bay will help a lot.
    Start removing the following screws:
    pull the tray up to release the hook for the oil dipstick and then separate from the manifold about 2 inches. Remove the connector on your left
    put the whole assembly to the right and hold it is place (I use a ty-rap for this)
    Here is the first "catch", the oil dipstick tube gets very (I mean very) brittle after a couple of years, so as it has to be removed for clearance, it may break so will need to be replaced. Be careful that when it breakes it leaves a little piece or plastic (orange)tube inside the metal part that goes to the oil pan. This has to be removed too, use an old flat screw driver with a bent tip to pull this piece. This looks like this:
    Pull the orange tube up, it will do a little snap and release like this:
    Now we can see where are we going: here!
    With the Channel lock, remove the clamp that holds the hose (center of picture above, push it towards the engine block) and separate the hose from the thermostat housing. Now, assemble the tools like this, the bottle is just a dimensional reference...
    Put a rag on top of the open dipstick tube to avoid getting any or debree into the oil. With the tools assembled as above, loose the top that holds the t'stat housing to the block, like this:
    There is enough space to work the bolt by hand:
    Now let's work with the lower bolt, like this:
    when it's loose you'll be able to remove the housing from the block, it will look like this:
    Remove the old o-ring and pull the old t'stat from the block, if you do a quick change (quick as in normal, not lightning fast) you should loose only very little coolant. Remember that the o-ring goes on the outside, over the t'stat! Now it should look like this:
    Time to reasemble. put the housing back in place, caution to not move the o-ring, the housing should be flush with the block. Hold everything with the top bolt, which can be worked by hand, like this:
    Now, with the magnetic pickup, hold the lower bolt like this and insert it into the lower hole on the housing:
    Bolt towards the housing:
    Bolt onthe housing:
    Now, use the short 10mm socket and the long extensions again to secure the lower bolt in place, then do the top bolt. Reattach the coolant hose. Now, insert the oil dipstick tube back into the metal base, remember that the square part on the side is to be reinserted on the manifold base later. Release the ty-rap (if used) that holds the tray that we moved to the right and put it back into it's position, on the manifold. Remeber to secure the oil dipstick tube into it's slot and reattach the connector we removed from the left side of the tray.. Reattach the 2 10mm nuts and the 2 5mm allen screws.
    Open the reservoir and top it off with coolant or water, depending on how much you did loose. Remember, that the OEM coolant, PENTOSIN G12 (Pink color), DOES NOT MIX WITH OTHER COOLANTS. If you do, it wil gel and create a mess.
    After filling the coolant, reattach the battery and turn on the car, leave it idling for 5 minutes and keep an eye on the evel as it may empty the reservoir filling the bubbles on the block. After the engine has idled for 10 to 15 minutes, check for leaks and go for a test drive.
    Hope this helps!
    thanks to RafaTT audi world
    Nov 2011
    37
    Fantastic, possibly worth making this write up a 'sticky'?
    bazil's Avatar
    BOOM BOOM
    Mar 2010
    Scotland
    135
    just searched for this again, please as seafar suggested add this as a sticky please
    Imola yellow S3 APY.
    Nov 2011
    37
    Quick update, changed the temperature sensor first as it's the easiest - still no change in the gauge .
    Changed the thermostat, both housing bolts are 10mm socket headed But also have 5mm Allen head
    socket centre's which was the way to get proper purchase on tightening, anyway topped it up with anti-freeze
    and took it for a run, success ! Temperature gauge now reading 90* Happy days.
    hoffmanvp3 likes this.
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Glad u sorted it mate. It's a nice feeling inside when u sort some thing
    Nov 2011
    37
    Quote Originally Posted by hoffmanvp3 View Post
    Yes ,the bottom bolt is awkward to get to but the 5mm Allen key socket worked a lot better than the 10mm socket.
    An hours work and not much more than a £10 for the parts.
    joe27's Avatar
    Jan 2014
    Kernow
    19
    Good write up! Took me 4 attempts to do this, cheers to ev one who makes contributions BTW Once you've done it you'll wonder why you had probs in 1st place! Cabin heats up real quick now, 90 degrees all day and more boost in 3rd gear Next job, drop the sump, pick up pipe & oil pump.
    May 2013
    Birmingham
    212
    I've done the thermostat and pickup not too long back it is nice once those jobs are out the way!
    joe27's Avatar
    Jan 2014
    Kernow
    19
    Good job! Apart from oil pump are there any other jobs I could do when sump is off? Any hickups to look out for when dropping sump, I#ve heard its easy enough job but beware of corroded bolts on the sump!?
    May 2013
    Birmingham
    212
    I did my dogbone bushes at the same time as it's roughly the same place and that was quite an improvement. I went for the red powerflex and it's isn't harsh but has stopped the knocking I was getting.
    With the pick up mine went surprisingly well nothing seized and I didn't have a problem with the bolts 10mm socket with extension and wobble on it and long Allen keys are handy! Just gt the car high as possible no fun under there scrabbling about! Only issue came at the end torqueing up the little bolts it sheared the first one I tried so finished the rest by feel. It was getting late so I left the one that had sheared off and luckily no leaks so I'm gonna have a mess when it's a bit warmer no fun in the middle of winter! Hoping my screw extractors will do it but might drop the sump again if needs be. I didn't do anything past the pick up as it wasn't as bad as I'd expected all seemed ok down there.
    joe27's Avatar
    Jan 2014
    Kernow
    19
    Thanks WallmOnkey! You sound way more advanced than me, think I may be a little naïve about this job. If I do it rkn I'll stick to pick up pipe and cleaning sump out, possibly oil pump. Also heard that good oil, larger filter & 5k oil /filter changes can clear out a lot of sludge - another way of cleaning the engine out!? sounds easier than grovelling in oily overalls & scrapping knuckles, but its a good job to do I guess
    Did you change your oil pump?
    May 2013
    Birmingham
    212
    It was the first job like that I'd done to be honest having this S3 has been a big learning experience! I have done 5k oil changes for a few years on my old cars I figure anything to keep them running is a bonus and it's relatively low cost! I left the pump as it was as I hadn't had any issues with the car and it was surprisingly good down there I did consider it. I guess it doesn't hurt whilst your down there.
    joe27's Avatar
    Jan 2014
    Kernow
    19
    Cheers again! Like me then, learning as I go. Had a look at an S3 a month ago, rkn next will be 2.0 A3 quattro or S3 - ultimately an R8 Loving the A3 quatty so far though '99 plate & clutch pedal breaking only real prob so far.
    Cheers for share of info tho, think I'll do the oil filter/pickup pipe in one, I'll defo look at dogbone bushes too, I read the yellow powerflex were the babies!? You're rolling an S3 though!? Are there different recs than an A3? Did you have probs compressing the assembled bush to fit into place?
    joe27's Avatar
    Jan 2014
    Kernow
    19
    Quote Originally Posted by joe27 View Post
    Me bad, I'm talking about the yellow powerflex engine mount bush - amateur I am lol
    May 2013
    Birmingham
    212
    For the dogbone I'd heard a few horror stories of seized bolts and needing the break the mount to get it off so I ordered the ths one ready assembled. It did cost a bit more but I couldn't have the car off the road for more then a day at the time. So obviously after doing that it all came apart perfectly no drama lol. A few people said the yellow was too harsh so I played it safe with a red one!
    joe27's Avatar
    Jan 2014
    Kernow
    19
    Just finished my nightshift, pleasure to get in the car and see 90 degrees after a few miles, warmer in the cab too lol. Good tip for the pre assembled unit Sounds ideal for my situation too. Can't wait for next w/end to get on with things!
    One more que: how'd the S3's drive? I've never driven one but heard they handle like on rails, quick too? How does upgrading change the performance? I'm torn between leaving mine/remapping, its never been modified & is in really good shape, I'm certain it'll go for another 100k as it is with little probs (jinx lol). But heard remaps turn it into another car If I go for power though, I want proper power, not just another 30/50 BHP! Rkn I'd want to throw 3-5K at it & ramp it to 240+ BHP...1st things 1st though lol, drop that sump to achieve a really clean motor. Cheers for your feedback Wallmonkey
    May 2013
    Birmingham
    212
    I do really like the S3 I had a TDI 150 Bora last the Audi does stick the power down a lot better and I feel more confident in it going quicker. I spend 90% of my time in a work van and my girlfriend drives the S3 I only really get chance on the weekend lol. I'm in a bit of a similar situation currently it's on standard power but want to wait til everything else is ready before starting on the engine.
    Seems like a long road ahead as we are currently saving so the car gets a treat once a month! I think engine will be last on the list try and get all the parts together new clutch, rods, turbo and have it all done wish it was all happening now these build threads are terrible for my bank account!
    joe27's Avatar
    Jan 2014
    Kernow
    19
    Last one for now, I did find this: A3/S3 FAQ / How To's / Tuning Info STICKIES - PLEASE READ BEFORE POSTING You've prob seen, it has a oil pickup pipe for s3 guide cheers 'n' gone!
  1. Thermostat location
    By DEEJAY TQS in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd March 2012, 04:13
  2. 2.5 v6 TDI thermostat location
    By sprinter1801 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th April 2008, 03:50
  3. Thermostat location 1.8T?
    By JayB5UK in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th October 2007, 15:31
  4. thermostat location?
    By Rob_k in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th July 2007, 13:31
  5. Thermostat location? anyone? A4 TDI
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd February 2007, 10:09
