Results 1 to 9 of 9
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Exclamation Defeated ECU’s ??
    Hi guys
    Its looking like i may need to replace my ECU
    I've seen a few ECU’s for sale saying that they are immobiliser defeated so they are plug and play.
    What I'm wondering is what happens about the dash as when you turn on the ignition, wouldn't the immobiliser part in the dash try and communicate with the ECU and when it doesn't find the immobiliser part in the ecu stop the car from starting?
    Or am i way off...lol
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Immo defeat just turns the immobiliser off essentially but the new ECU can be re-coded if required... personally I would prefer to retain the immobiliser
    There is no issues with the dash and no lights stay on with immo defeat
    <tuffty/>
    May 2012
    RETFORD, NOTTS
    1,753
    where abouts are you? Ecu swaps are something I can do quite easily the correct way. Immo defeat I only really do to diagnose issues.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    <tuffty/>
    Thanks for that tuffty mate
    I've always thought that the immobiliser part of the car was split into two and so when you turn the key, the key chip would need to sync with half the immobiliser in the ecu and half in the cluster.
    From what your saying its more like the car has two immobilisers (one in the ecu and one in the cluster) that are synced together ?
    Quote Originally Posted by @udi A3 View Post
    Thanks mate
    But I'm in london so a bit far from you.
    I've heard its easy enough to program it in using vag can commander 1.5 but I've also read some horror stories....lol
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,378
    The immobiliser is in the cluster, and tells the ECU its allowed to start the engine if the key is valid.
    So key is synced with cluster, and then cluster is paired up with the ECU.
    TD5 Land Rover Defender build
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Oh ok.
    Wouldn't that then mean that immobiliser would still be effective even with a ecu defeat, as if you tried to start the car without the key then the cluster wouldn't tell the ecu to start?
    RobinJI's Avatar
    Jul 2012
    Chard, Somerset
    147
    With the immobiliser defeated, the ECU won't care what clocks are connected to it, the clocks don't even have to be there. It's the ignition switch that tells the engine to start not the clocks, and the ECU reacts accordingly by checking with the clocks whether it's meant to be running or not. With the immobiliser defeated, it just doesn't bother checking.
    1.8 20v turbo converted '88 Scirocco - ASN Build Thread
    "Stick a V8 in it!"
    15,378
    exactly. With it defeated the Cluster could say "DO NOT START" or even nothing at all, and the ECU would ignore it and allow the engine to start anyway.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Thanks mate I get it now
    if I get one without the defeat is it easy enough to get it to work using the cheap vag can commander / leads ?
  1. ECU tuner suggestions...
    By dougan in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd September 2003, 15:38
  2. Oettinger ECU
    By Drill in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2003, 08:49
  3. ECU
    By nathan in forum General Technical / How To
    Last Post: 16th June 2003, 14:33
  4. ecu remapping
    By nathan in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th June 2003, 18:44
  5. ECU part number
    By stumunro in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2003, 12:49
