Volks AutosChris Nott
Results 1 to 12 of 12
    Oct 2013
    70
    Driveshaft wont reach gearbox?
    Ive just finished changing the clutch on my car but I have encountered a problem. The driveshaft is short of the gearbox by about half an inch on the drivers side.
    The engine seems to be mounted to the far right of the car as possible already. . Not sure of my options from here?
    Can anyone help?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    the Inner CV is "telescopic", you should be able to extend it out to fill the gap?
    TD5 Land Rover Defender build
    Oct 2013
    70
    Ive tried that but it still is a bit short and the drive shaft insidr it isnt mating up to anything inside. Really confused
    "Stick a V8 in it!"
    15,385
    Its a bolted flange...
    The driveshaft attaches to the inside of the CV joint, the outside of the CV joint attaches to the gearbox...
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,374
    Have you changed any of the parts involved?
    Same driveshafts? same gearbox?
    if so, then something is very odd here, as they obviously fitted when they came off!
    Did you remove the lower ball joints for any reason during the work? I've seen people refit these wrongly in the past causing alignment issues....
    Oct 2013
    70
    Ive removed the whole passanger hub to get the passenger sidr driveshaft off. I havent touched the drivers side, all I did was undo the drivers side bolts. The engine mounts were removed on the passanger and during the clutch change the drivers side pin came completely out of its engine mount but like I said, the engine is back in position now, adjusted as close to the drivers side as possible
    Oct 2013
    70
    Same gearbox too. I have the driveshaft bolted in now but im worried because it seems a bit strenuous on the bolts. I raised the drivers side wheel up with a jack to allow for a little more play.
    "Stick a V8 in it!"
    15,385
    The inner CV has perhaps got stuck or one of the balls has become dislodged if you've overextended it in some direction.
    Oct 2013
    70
    So your saying all the motion from the gearbox goes through the bolts of the cv joint and then the driveshaft that I can see inside the cv joint connects inside that?
    As in it goes in this order of motion, gearbox, cv joint, driveshaft..... not gearbox, driveshaft?
    Sorry im confusing myself lol.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    It is your car your working on......
    Oct 2013
    70
    Ok I got it bolted on. The driveshaft wasnt spinning freely, it felt like it was catching something. On further inspection I can feel one of the ball bearings in the rubber gaiter.
    "Stick a V8 in it!"
    15,385
    you'll need to strip the joint down and refit the ball.
  1. Gearbox? Driveshaft ? noise can someone help please ?
    By dentsy in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 20th February 2011, 10:57
  2. My gearbox and driveshaft have fallen apart help!!
    By S3 Adj in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th April 2009, 21:06
  3. Sequential Gearbox Anyone?
    By AL_B in forum General Technical / How To
    Last Post: 21st February 2003, 12:58
  4. Gearbox Repaired!
    By Joshie in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2003, 08:59
  5. DSG auto gearbox... confirmed?
    By jamesa in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th January 2003, 14:21
