EM TuningAH Fabrications
Like Tree1Likes
  • 1 Post By badger5
Thread: Audi S3 MAP sensor question
    QuestMS's Avatar
    Jun 2013
    Romford
    66
    Follow QuestMS On Twitter
    I will be changing my intercooler setup soon and plan on changing the restrictive MAP sensor tube also.
    I was thinking about welding a flange onto my inlet manifold just behind the throttle body and extending the wiring loom if too short. Then it would just be a case of a straight joiner in place of the plastic MAP tube.
    Would mounting the MAP sensor directly to the manifold have any diverse affects? (Surely it would be the best place to have it anyway?)
    Thanks in advance
    Relentless v3 manifold, custom 3" decat downpipe, custom 2.5" exhaust system, Forge wastegate actuator, Forge 007p DV, Badger5 3" TIP, ITG Maxogen filter, Draft44 catch can, Trackslag charge pipe, 2.0TFSI coil packs, n249 delete, FMIC, poly bushed, FK coilovers, adjustable rear arms, 19" RS4 style alloys,
    RIP S3dave
    May 2004
    nr Glos
    7,195
    yes
    it will run like a bag o shyte
    the ecu is not going to know what vacuum signal is
    A3-Lee likes this.
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    QuestMS's Avatar
    Jun 2013
    Romford
    66
    Cheers for the quick response buddy, I will fit it in pre TB then.
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    448
    Nothing wrong with its standard location tbh
    QuestMS's Avatar
    Jun 2013
    Romford
    66
    I just thought it might be easier to get a 2.5" tube through the gap without a map sensor in it, move it a little bit further up the line kinda thing. Not much space on the S3
  1. Quick vagcom/map sensor question
    By loafofbrett in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2010, 11:12
  2. Audi S6 rear parking sensor question about replacement
    By technics100 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th March 2009, 14:33
  3. MAP sensor or MAF sensor
    By imported_stanA3turbo in forum Tuning
    Last Post: 17th August 2004, 23:09
  4. New Audi S3 Owner - Few Questions
    By imported_dpo in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th July 2004, 22:52
  5. Considering an Audi A3- lots of questions :D
    By DelBoyUK in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th June 2004, 15:25
