Alarm coding s3
orig setting 15178
to beep on lock 16202 (plus 1024 on to 15178)
to beep and lock 16234 ( plus 32)
Go to the central locking module and select coding.
The 'soft. coding' figure in the box needs to be increased by 1024 for beep locks, and another 32 for auto-locks at 15MPH.(i.e. if your figure is 14000, you change it to 15024 for beep, 15056 for beep and auto-lock)
I don't think the e-bay lead will access the coding block, although I may be wrong.
Make a note of the 'soft. coding' number when you access the module, so you can go back if it goes wrong
try this but take a note of thr original coding.
if it goes wrong dont blame me....
think the 15178 flashed the lights.
i thing i got this on the vcds forum on here
