Volks AutosMonster Motorsport
    Oct 2013
    70
    Quick answer needed from Gearbox gurus
    I can see the timing mark on my replacement flywheel but I cant see the timing mark on the engine block. .. where should I be looking? The car is a 1.8t 150.
    Thanks a lot
    Oct 2013
    70
    Found out my answer. ..
    The*flywheel*can only be bolted on 1 way since it has 6 bolt holes and 1 of those hole is offset. So it is impossible to put bolt the*flywheel*on incorrectly.
  1. Quick Answer needed - Adaptors & Offset
    By Peety in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th July 2009, 17:00
  2. Quick Answer Needed :)
    By edition in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th March 2009, 13:08
  3. Oil, quick answer needed please!?
    By campbell in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2009, 16:29
  4. Quick answer needed
    By Glenn A4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th January 2008, 23:49
  5. Quick answer needed....please
    By alecblack in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2007, 14:09
