Quick answer needed from Gearbox gurus
neap38
NULL
I can see the timing mark on my replacement flywheel but I cant see the timing mark on the engine block. .. where should I be looking? The car is a 1.8t 150.
Thanks a lot
Found out my answer. ..
The*flywheel*can only be bolted on 1 way since it has 6 bolt holes and 1 of those hole is offset. So it is impossible to put bolt the*flywheel*on incorrectly.
