AH FabricationsVolks Autos
    Nov 2011
    35
    A3 8l '98 Help,Temperature Gauge not working.
    Howdy folks, my (A3 8l 1998)temperature gauge seems to have stopped working. I'm still getting warm air in the cabin but not exactly that hot that I need to turn the temp setting down. Currently set it at 29 degrees and it's warm not unbearably hot. It also takes a while to get warm. The temp gauge isn't going up at all.
    What do the experts think?
    Thermostat? Or Temp Sender Unit? Possibly both?
    Any help opinions, Thanks.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,927
    id say stat for the low temp heat
    and maybe cts for the non working gauge
    or maybe a ****ed gauge
    Nov 2011
    35
    Thanks,I'll start with the thermostat, anybody got a location photo of the housing ?
    Aug 2012
    43
    I would think before you remove the thermostat, first try switching on the AC, if fans come up then I don't think its the problem, I think u need to check the radiator switch.
    However, the stat is located under the battery.
  1. coolant temperature gauge not working.
    By fdt140876 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st March 2012, 00:16
  2. Temperature gauge not working, help!
    By B5QUAT in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th May 2011, 13:45
  3. Temperature Gauge - not working
    By cheekeemonkey in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th October 2008, 18:02
  4. Temperature gauge not working, bit of a problem
    By cookie_a3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2008, 12:27
  5. Temperature Gauge not working!!!
    By MickA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st March 2005, 08:55
