Chris NottVolks Autos
Results 1 to 13 of 13
    puggsy21's Avatar
    Oct 2013
    Kent
    82
    Toyosport downpipe and decat
    hey all,
    so today i fitted my new discs and brake pads which are alot better got grooved and dimpled all round and new pads plus i fitted my toyosport downpipe and decat and added my miltek cat back system need some exhaust paste where the pipe joins are
    My question is i went to take the car out for a spin see how the brakes and exhaust are but on pulling away i could hear what sounded like the driveshaft rubbing against the downpipe as it gets louder when you use more throttle i didnt go far, 50 yards or so once i heard noise i parked it back up
    what is my best or easiest option to correct the issue and would i need to take downpipe back off.
    Cheers for any responses
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    Best bet would be to get under it and see if there is any telltale rub marks then take it from there as to how and where to move...
    Currently rolling in a SKODA!!!
    Scullies's Avatar
    Feb 2012
    Dubai
    1,207
    my relentless also rubbed on my ko4 setup. I manage to fit the hanger pin through the center of the rubber bushing. Took some effort to get it in there.
    puggsy21's Avatar
    Oct 2013
    Kent
    82
    Scullies which hanger/rubber bushing are you referring to
    Scullies's Avatar
    Feb 2012
    Dubai
    1,207
    on the relentless DP there is a rod that sticks out off to the side of the pipe, before it joins the cat or decat. It fits into the stock exhaust rubber support.
    I managed to raise the DP a little bit up towards the floorpan, by fitting the rod into the center of the rubber support. Its not meant to fit in that position though.
    puggsy21's Avatar
    Oct 2013
    Kent
    82
    here is the one i have got it doesnt have the hanger like yours does
    Scullies's Avatar
    Feb 2012
    Dubai
    1,207
    aah you have an A3. I assumed you had a S3 when I read that the flexi was rubbing on the drive shaft. Blonde moment.
    puggsy21's Avatar
    Oct 2013
    Kent
    82
    lol ha ha, so do you think that is happening to mine the flexi rubbing on the drivershaft
    Scullies's Avatar
    Feb 2012
    Dubai
    1,207
    I really don't know bud, best to have a look where the flexi is sitting
    Oct 2011
    greater mcr
    108
    Get under the car mate (when exhaust is cold) and move/rattle it about up and down - left to right, then see where it touches. There's usually some movement in brackets so-on.
    2002 bam s3, 3" custom turbo back/decat, unicorn MD custom map with pops n bangs ;-), b5 tip, s2k filter, forge 008, uprated intercooler, more to come :-)
    puggsy21's Avatar
    Oct 2013
    Kent
    82
    ok cool will do cant do it at the min as not feeling well
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Tactical dent where it rubs... FWD or quattro?
    <tuffty/>
    puggsy21's Avatar
    Oct 2013
    Kent
    82
    FWD tuffty
  1. 1.8T downpipe and decat
    By audi_a3_turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2011, 20:57
  2. chinese 3" downpipes and decat prices down??
    By Chlippo in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2010, 10:09
  3. ebay 3" downpipe and decat fitting - Is it hard?
    By DaveA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th October 2010, 23:08
  4. hassle with downpipe and decat
    By tyson in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2010, 21:00
  5. 3" downpipe and decat. what do you guys think??
    By robbie282 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2010, 18:23
