Stacey: your TSR man will limit the size of comp cover from memory... bare that in mind.. Not sure how much more room there is
It also surged on your current setup as I recall.
Precision do the 6235 with the same T04B comp housing that am currently running
Not sure how much that smaller comp housing will perform on a compressor that big and wether will be that detrimental to performance? Mine did have surge and had to be tapered in up until 5000 iirc where boost was then let loose
Not currently planning on upgrading but it's certainly floating around in my mind, if I do though it will be substantial to a billet 35r (precision or HTA) of some description as not worth doing otherwise and the tial housings and Garrett core mean it will be a drop in solution regarding dp and lines only headache will be comp cover
I expect to be pulling the engine and box next month once finished decorating 3rd room as not starting another till new year
With regards to the meth in the fuel it's something would quite like to try but seems like it's not favoured and worth the grief
Maybe should start a petition for E85 obviously for the benefit of being Eco friendly
