EM TuningJMB Retrofits
Results 1 to 8 of 8
    willh92's Avatar
    Jul 2013
    Portsmouth/Rushden
    156
    Question '99 S3 quattro system
    I have a '99 S3 and have heard various things about Haldex systems, etc.
    Are all quattro systems Haldex, would my S3 be a Haldex system or simply full time 4 wheel drive,
    if so what is the distribution of power front and rear for a regular 4wd system on my year S3?
    Thanks,
    Will
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    S3 is haldex.
    Hdaldex and Quattro are completely different
    our s3s are 4wd when they need to be, and will send up to 50% to the rear when needed, when its not, its a fwd car, but you will never notice that.
    Its a smart system, ours is a fairly primitive one tho.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    886
    Add Vex182 on Facebook
    "quattro" is just what Audi call all their 4 wheel drive systems. The way they work and brand depends on the model. All transverse engine models in the Audi range use haldex as their system. Basically a clutch pack that engages the rear wheels when slip is detected. It is always engaged a little bit but can clamp completely to give 50% of power to the rear when needed but it won't usually last long, e.g lunching in the wet or cornering hard.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    willh92's Avatar
    Jul 2013
    Portsmouth/Rushden
    156
    Right I see, so our S3 models have this Haldex system then?
    S3 - APY silver
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Yes... Generation 1 haldex...
    <tuffty/>
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Hunt down a gen 1 haldex Blue controller to unleash the couplings full potential.
    Anticipating further questions lol
    Fire away
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,283
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by hoffmanvp3 View Post
    Fire away
    Or we could be a little bit more patient with this thread
    50/50 haldex mod
    Those Haldex controllers aren't exactly cheap
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    chaz20vt's Avatar
    Aug 2012
    425
    Yea I'm waiting for the above to happen
  1. How long should 2.8 / quattro system last?
    By Al Uu in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th January 2008, 11:16
  2. Quattro System?
    By downie in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th February 2007, 16:12
  3. Quattro system, always on?
    By imported_mustwin1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2005, 14:36
  4. Quattro system ...
    By sambo in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th November 2004, 15:47
  5. How does our Quattro System work?
    By imported_ZeroK66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th August 2004, 11:00
