EM TuningChris Nott
Results 1 to 11 of 11
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    998
    Exclamation Another Hard One :-(
    Not that....lol
    I was driving down a quite road today (so not driving fast) when all of a sudden the revs started pulsing and the accelerator pedal stopped working completely.
    I pulled over to the side of the road and used my generic fault code scanner i have linked to my iphone and it gave these codes:
    Stored Codes
    P0223
    Throttle/Pedal Position Sensor/Switch “B” Circuit High
    P0223
    Throttle/Pedal Position Sensor/Switch “D” Circuit High
    P0223
    Throttle/Pedal Position Sensor/Switch “E” Circuit High
    Pending Codes
    P0135
    O2 Sensor Heater Circuit Bank 1 Sensor 1
    P0138
    O2 Sensor Circuit High Voltage Bank 1 Sensor 2
    So i called the breakdown company and when the guy eventually showed up he just had a quick look and said “i hate electrics” “where do you want me to take it”.
    When i got home i ran vagcom on it and got this:
    Address 01 -------------------------------------------------------
    Controller: 06A 906 032 HJ
    Component: 1.8L R4/5VT 0002
    Coding: 11500
    Shop #: WSC 00000
    WAUZZZ8L52A001557 AUZ5Z0A5293082
    5 Faults Found:
    18039 - Accelerator Position Sensor (G79): Signal too High
    P1631 - 35-00 - -
    18042 - Accelerator Position Sensor 2 (G185): Signal too High
    P1634 - 35-00 - -
    17581 - Angle Sensor 2 for Throttle Actuator (G188) Signal too High
    P1173 - 35-00 - -
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 35-00 - -
    Readiness: 0110 1101
    Address 03 -------------------------------------------------------
    Controller: 1C0 907 379 E
    Component: ESP FRONT MK60 0104
    Coding: 0019970
    Shop #: WSC 06435
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory
    I've done a bit of googling and it seems that it could be one of my o2 Sensors , The throttle body sensors, The throttle pedal sensor or the ECU.
    I've also tried re aligning the throttle body.
    If the car is cold and i start it up it seems to run ok (the accelerator pedal still doesn't work) while the choke is on but as soon as it fall back down on the revs, they start pulsing again.
    Has anyone on here had this happen to them ?
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,355
    throttle body for the first 3, and possible boost leak for the other
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    998
    Quote Originally Posted by Byzan BAHons View Post
    Thanks for the reply
    That's what i thought at first from the codes given, but on other forums and the ross tech site they point more at the o2 sensor and the throttle pedal sensor.
    Am i right in thinking that if i take the plug off the throttle body and put a multimeter on the plug while getting someone to put their foot down on the accelerator pedal, the voltage should go up on the multimeter?
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    998
    Update.....
    I have now replaced the throttle pedal the the throttle body and the o2 sensors but the problem still remains.
    I've manage to realign the throttle body with vagcom but all that has done is settle the revs.
    The car now runs (although a little bit lumpy) but nothing changes if i put my foot down on the pedal.
    When i clear the fault code these ones instantly come back:
    P1631 - 35-00 - -
    P1634 - 35-00 - -
    P1173 - 35-00 - -
    17976 - Throttle Actuator (J338): Mechanical Failure
    P1568 - 35-00 - -
    Coding: 0019970
    Shop #: WSC 06435
    1 Fault Found:
    Any ideas guys as I'm out of them
    Apr 2004
    12,355
    you changed the throttle pot on the acc pedal and the throttle body and problems still exists?
    You checked wiring? only other thing I guess could be water ingress into ecu plug
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    998
    It looking like it could be the ECU mate :-(
    Every thread I've read with the same symptoms as mine end up being that the lambda cable has grounded on the exhaust and shorted out the driver on the ECU.
    We had the car up on the ramp today and all the wires look ok so were a bit lost now.
    Any ideas ?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,904
    I've certainly heard of lambda heater/wiring failures causing throttle issues!
    Your original scan also had codes for the lambda.
    Be worth trying another ECU, but make bloody sure the lambda wiring is ok, so you dont kill the new one!
    TD5 Land Rover Defender build
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    998
    That's what I'm worried about mate.
    I don't want to spend out on another ecu only to have it blow on me the second i plug it in.
    We checked the wires and they didn't look like they had melted on the exhaust...etc but maybe they have shorted internally?
    I was going to just changed the o2 sensors just to be safe but It could even be that something else has shorted and blown it, I'm just running out of ideas where else to look.
    "Stick a V8 in it!"
    14,904
    replace the probe and check the wiring for shorts with a multimeter.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    998
    Bit of an update.....
    Had someone do some tests on all the electrics and they run some earths to the ecu and the throttle pedal and everything is working.
    Something must have burned out an earth component in the ecu but his wires have bypassed it.
    I'm still going to change the lambda sensors as i think their a bit iffy. but now i have a bit of time to find out how to use vag can commander to recode an ecu.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    998
    When you've heard of the sensors frying the ecu, where have you heard them failing?
    I've hear that the wires touch the exhaust and shorting it out but they are never clear what part of the wiring come in contact with it.
  1. Another Welsh One
    By Bronwydd in forum The Welcome Section
    Last Post: 24th June 2011, 16:30
  2. Another new one here
    By Andrew@A.L.D in forum The Welcome Section
    Last Post: 27th June 2009, 05:17
  3. Another maroon one!
    By ash_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2009, 22:34
  4. another new one
    By MAC 1 in forum The Welcome Section
    Last Post: 12th March 2009, 21:52
  5. Polished Bliss: ANOTHER bad one.......
    By Clark@Polishedbliss in forum Detailing
    Last Post: 14th December 2007, 17:17
