AH FabricationsChris Nott
Thread: 8J Alloys
    A3 NICK's Avatar
    BOOOOOOOOOST!!!
    Aug 2012
    South East
    52
    8J Alloys
    Hi all
    Just wondering if 8J alloys would fit my 98 A3 without spacers? If I do need spacers what size would be best? Tyres that are going on will be 225/45/17.
    Thanks all!
    Current Mods
    KO3s, TIP, Longlife custom Exhaust, 3inch Downpipe/Decat, FMIC, Forge 008p dv, VR6 Clutch/G60 Flywheel, Stage 1 Revo Map, Momo GTR Alloys.
    Waiting to fit
    Calibra 346cc injectors, JOM Coilovers and some bits and bobs.
    Sep 2013
    26
    think mine are 8j mate and i dont have a problem.
    Jul 2011
    Berkshire, Surry, Hampshire tri-intersect
    351
    8J should be fine, depends of the off set... Anything below ET35 and you may start having clearance issues, anything Over ET45 and you'll probably want spacers otherwise they'll look weird.
    Do you know the off set? . . Should be stamped inside the rim
    A3 NICK's Avatar
    BOOOOOOOOOST!!!
    Aug 2012
    South East
    52
    Yeah just checked they are 8JX17/ ET35/ 5x100 so they should be all good then? And is 225 a big enough tyre size or would it be better of they were bigger?
    Current Mods
    Waiting to fit
    Nyteryda
    Surrey
    222
    I wouldnt go wider on the tyres if you are planning on slamming it, if the fronts rub on the arches it can cause big problems cornering at higher speeds
  1. Alloy wheel cleaner & Brake callipers
    By Banwell in forum Detailing
    Last Post: 28th May 2003, 10:24
  2. New alloys
    By Drystone in forum Other Brands & Models
    Last Post: 11th April 2003, 09:18
  3. S3 ALLOYS ??
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2003, 16:47
  4. NO NO NO.... Just scratched my Alloys
    By Chimera in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2003, 16:40
