Volks AutosEM Tuning
Results 1 to 7 of 7
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,078
    S3 - under damped or under sprung?
    So a thought a crossed my mind a few days ago. Are the S3 8Ls under/over damped or under/over sprung?
    The standard handling mod on here seems to be to do the B8s and H&R or Eibach springs, but that's usually because the dampers are older and wouldn't take a lowered spring for very long.
    What are the cons of just doing one or the other?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,848
    Out the box they are ok, a safe and comfortable setup, but the dampers seem to go off around 40k miles+, springs snap over time due to corrosion what ever the mileage! and it's a common problem on most modern cars these days!
    Bilstein shocks are more damped than OEM shocks, this give the car better control of its suspension, but at the expense of ride comfort, it still feels OEM though, not overly firm. They will work fine with standard springs.
    Lowered springs usually have higher spring rates, as you have lowered the car, there is less suspension travel, so the springs are harder to cope with it. This makes them more springy lets say, so the dampers need to do more work. OEM shocks are ok when fresh, but matched to a set of lowering springs, they will just deteriorate quicker. Uprated items like the Bilsteins would obviously be a better shock absorber to control these lowering springs.
    You've got to have a laugh!
    JD09's Avatar
    Dec 2009
    3,078
    Cheers Joe. I replaced everything (shocks, springs, drop links) about two years ago, spending over a K on that as just didn't want to go down the modding route. Fresh as a daisy still, as protected the new stuff and keep it clean. But now starting to think I should have gone B8s and H&Rs.
    R32 rear ARB is first on the list and will see how I get on with that. The thing really does roll heavily but spending another K on it is just a bit too much of a dump (pays off a years mortgage overpayment, which I'd rather do tbh!).
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,848
    Quote Originally Posted by JD09 View Post
    Check your tyre pressures? Why not stick a few more psi on the rears before you do the R32 rear ARB mod and see how you get on? I personally wouldn't recommend doing the ARB mod on standard shocks, but it's entirely upto you.
    JD09's Avatar
    Dec 2009
    3,078
    Quote Originally Posted by jojo View Post
    Not heard of either of those before, fella. PSI at the rear being higher = less understeer?
    And I thought on standard suspension the R32 ARB mod was a "must"?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,848
    Just think of sticking higher pressures in the rear as simulating a bigger rear ARB, not less understeer as such, but better turn in, of course it may change the rear end ride a little, have a play. R32 ARB mod isn't a 'must do' mod in my opinion, it really depends on how you use your car.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    824
    Add Vex182 on Facebook
    I replaced the front wishbones, front shocks, front springs, all drop links and rear springs all with OEM and it felt nicer to drive. Just what I want and I don't feel it rolls that much compared to before but I drive it just like a normal car anyway.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
  1. Lowering under bonnet temps - increas performance?
    By pure in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2004, 19:59
  2. Where to get an MP3 Head unit for under 99?
    By comdw in forum In-Car Entertainment
    Last Post: 11th December 2003, 13:33
  3. small puddle of water under car each time
    By TDI in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th December 2003, 15:54
  4. Venting In Under Arch Cover.
    By Richard in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 19th October 2003, 12:52
  5. Anyone had warped disks replaced under warranty?
    By CarloTT in forum TT/TT-S/TT-RS Forum
    Last Post: 5th August 2003, 23:09
