Sky InsuranceChris Nott
    Oct 2009
    14
    Broken Ignition Barrel
    Hi my ignition barrel housing has broken when I removed the Ignition switch a small blade of metal came out as well. I was just wondering if I just have to change the housing which the switch and barrel sits in as the switch and barrel look fine. Also I presume you have to drill or cut the two bolts of which hold the housing onto the steering column ? Any help much appreciated as the car is in bits at the mo :-( oh its a 1998 s3 )
    May 2012
    RETFORD, NOTTS
    1,707
    Ive never replaced one but I could get a new one to fit your key for approx 80.00+ pnp.
    You may be able to get a local locksmith to rebuild yours for you, doubt it would be that cheap though. Where abouts are you?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Oct 2009
    14
    Thanks I have another barrel and switch it was just the metal parts inside the housing that has all broken. I am going to have to try and get another housing and try and remove this one from the steering column . Just not sure about the two studs holding it on ,I think they have to be drilled out.
  1. Broken ignition barrel :((((((
    By andya3turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2012, 22:24
  2. Fitting Ignition barrel Audi A4 1.9TDI 130BHP
    By kashiskash in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th March 2009, 21:38
  3. Audi A6 3.0TDI Quattro (Ignition barrell???)
    By Brian_A6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 14th November 2008, 17:27
  4. Ignition Barrel Problems
    By m_o_w_g_l_i in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2005, 19:23
  5. Replies: 3
    Last Post: 23rd June 2005, 22:53
