EM TuningChris Nott
    May 2012
    RETFORD, NOTTS
    1,706
    Sick of boost leaks, what pipework to fix it?
    So today i had another episode of leaking boostpipes and squeeling noises under various loads and temps.
    Who has successfully fitted a FMIC on a tdi? What pipes did you use what lengths and angles?
    I was hoping to grab the oem solution from a mk4golf or bora but they sell faster than things that sell very fast it would seem.
    ideas?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,352
    Where are the leaks coming from? Are from split hoses? Are they leaking due to the clapping? Do the hoses pop off?
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    May 2012
    RETFORD, NOTTS
    1,706
    they havent popped off this time, and tbh im sick of trying to smoke test it. sometimes they come and go. i think its around the top of the intercooler. I want to get rid of the whole lot and fit a front mount r charge cooler tbh, no more flexing and moving of bad parts.
    replacing the pipes with new or even the seals, would be costly and probably pointless!
    Unless you think otherwise?
    Jan 2011
    Glasgow
    226
    I would also like to know the correct pipe work for vacum hoses for my 8L S3
  1. whats the most likely boost leak location?
    By danger S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2010, 09:14
  2. boost leaks, what can the effects be?
    By quattro1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2010, 18:28
  3. Oil/Boost Leak
    By chimmo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2005, 10:48
  4. Follow up from Boost Leak
    By StevieBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th December 2004, 13:43
  5. Boost Leak
    Last Post: 8th December 2004, 20:47
