EM TuningBadger5
    Mar 2013
    Bridgwater, Somerset
    45
    Rear Disc cracks
    Lately I have noticed what appears to be cracks in the rear disc's.
    The lines seem to run from the center of the disc to outer edge.
    How can I be sure they are hairline cracks ?
    The one on the passenger side has an obvious looking crack.
    Mar 2013
    45
    I replaced the rear disc's today but found I had to screw the rear pistons in a bit to enable me to get the caliper back over the pads.
    I didnt need to change them as they were nearly new.
    But I had to remove the calipers to enable me to screw the piston in on each side.
    So this meant bleeding the rear brakes again.
    I thought everything was okay but when I started the car up the red brake warning alarm and symbol was displayed on the dash.
    Also the pedal pumps up and then loses pressure and then firms up and loses pressue once again.
    Does this mean I need to bleed the brakes again ?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Yes Bleed them again, the red warning is low fluid in the reservoir, so make sure thats topped up
    Mar 2013
    45
    Well I bled them over and over again with the same result.
    However I was thinking what if I bled the master cylinder.
    So I bled both nipples and the brake pedal firmed up straight away with lots of air coming out of both.
    Lovely brakes now.
  1. Rear discs - special tool?
    By cjhill in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2006, 19:05
  2. rear discs/bearings
    By Danielson in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd January 2006, 20:30
  3. S4 Rear Discs/Calipers onto A4 Quattro?
    By imported_VaulterTim in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th September 2005, 16:59
  4. Rear Discs and Pads
    By in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th July 2005, 18:49
  5. rear discs and pads, help please.
    By S3tony in forum Handling
    Last Post: 8th February 2005, 10:48
