Monster MotorsportBadger5
Results 1 to 16 of 16
    Oct 2013
    17
    2002 s3 suspension and top mounts what should I get??
    Yesterday I took the s3 out and one of the front springs broke . Im thinking about just changing all the springs and shocks as its done 85k and everything is probably a bit tired now . While I was checking it over today I noticed the front top mounts have also seen better days so I'm going to change them at the same time.
    where's the best place to get new suspension and what should I go for oem or aftermarket . Iv had loads of after market setups over the years and have learnt some set ups have been to stiff for the road and just ruin the handling.
    Also the same for the top mounts where should I get them from and oem or aftermarket .
    The car won't be used on the track .
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,519
    I'm using ECP top mounts and bearings, no issues, and I have tracked my car.
    Oct 2013
    17
    Iv had a look round and I'm going to get seat Leon cupra r front mounts and bearings.
    What shocks and springs should I go for I'm not that intrested in coilovers as its not going to be used on the track and don't want to go to low . What are the weitec ultra gt lowering kits like they don't seem a bad price and only lower 20mm
    Oct 2013
    17
    Quote Originally Posted by jojo View Post
    i had a look on the ecp website but couldn't find the top mounts
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,519
    Quote Originally Posted by Donk1 View Post
    I thought I'd have a look myself, and you are right, can't find them online. I got them off a mate who works at ECP using my reg number. I had both new topmounts and bearings.
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    I had the Weitec Ultra GT 20mm lowering springs and shocks on my previous S3 and they felt like OEM. My current car has the Koni kit which feel more sporty , they are similar price too if bought from DPM Performance.
    Lemforder top mounts and bearings from GSF are ok if ECP don't have any.
    S3 Big Turbo
    Oct 2013
    17
    These are the kits I would consider
    weitec gt coilovers
    bilsteins
    kw v1 coilovers
    buy is really worth the extra money going for the Billy's or coilovers if its not going to be used on the track I'm after something that will improve the handling but not at the expense of being crashy and harsh to drive normally
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,519
    My Bilsteins are great for the road, not crashy at all, but they are not cheap.
    Oct 2013
    17
    bilsteins are good and used on a lot of cars from the factory but they expensive for shocks and springs.
    Im leaning towards getting some kw v1's as you can get them for £750 at the moment but are they that much better then say the weitec ultra kit that cost about £480.
    Big Al's Avatar
    Engine knackered!!
    May 2011
    West Midlands
    302
    Hi mate
    I'm selling a suspension set - you have a PM!
    Alistair
    Audi A4 B7 2004 red 2.0 TFSI Quattro Sport saloon, Servotronic steering, MFSW, CDIS, DRL with Coming Home, auto dual xenon lights/wipers/mirrors, split folding rear seats, 3rd headrest, centre armrest, Isofix mounts, RS4 rear ARB, pedals & carbon dash trims; Audi TTS 9Jx18alloys (2 sets), Yokohama AD08 summer, Conti TS830P winter 245/40/18 tyres, TPI 15/20 spacers/lockers, Pipercross filter, GFB DV+ turbo valve, NGK BKR7EIX plugs, Osram Silverstar Xenarc D1S bulbs. Build thread
    Oct 2013
    17
    Iv had a look on line and found bilstein b12 for £600 new so I'm going to give them a call tomorrow and probably going to order them .
    Oct 2013
    17
    Iv ordered the Bilstein b12 pro kit from GNJ Motorsport this morning hopefully I receive the kit this week so I can fit them at the weekend.
    Do the b12 kits come with new top nuts , damper sleeves and bump stops ?
    Iv found the following part numbers for the top mounts and the other bits im going to order.
    1HO 412 365A Threaded sleeve
    1ML 412 331 LCR Top Mounts
    1JO 412 249 Top mount bearing
    Are there any other parts that people would recommend fitting at the same time which may get damaged while fitting or would make install easier.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,519
    New top mounts and bearings when fitting new suspension is a good idea, as it's all coming off. But of a no brainer for the cost of the parts.
    Oct 2013
    17
    I thought I might as well do them while iv got it off. I never intended in doing much to the s3 but I knew I would ended up getting carried away iv used a broken spring as en excuse to change all the shocks and springs.
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    billy b8s , h&r s[prings -25mm leon cupra r top mounts adjustable rear arms , R 32 ARB jobs sorted
    red to red black to black blue to bits
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,277
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by fingermouse View Post
    + a full poly bush kit inc dog bone mount and 4wd alignment
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
  1. Ive had my pants pulled down and been conned what should i do
    By TDI140 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th September 2013, 12:56
  2. Replacement bumpstops and top mounts - stockists?
    By munchkincoupe in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th December 2010, 22:11
  3. Top mounts, What apig of a job!!
    By Oranoco in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th September 2009, 12:59
  4. WHAT SHOULD YOU GET FROM A FULL TANK OF PETROL??
    By grays3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2007, 20:48
  5. New Mobile- What should I Get??
    By murph in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 15th December 2006, 07:34
