EM TuningSky Insurance
Like Tree1Likes
  • 1 Post By @udi A3
Thread: Fuel pressure gauge installation.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    I'm wanting to test my fuel pressure ready for further mods.
    I'm looking at getting an inline fuel pressure gauge.
    Can anyone suggest the best location to install it. I'm guessing its just a case of cutting the fuel flexi line adding the brass t-piece with good quality jubilee clips and checking all totally sealed.
    Where have people installed theirs?
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    May 2012
    RETFORD, NOTTS
    1,753
    Is there a schrader (sp) valve on the fuel rail?
    s3dave likes this.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by @udi A3 View Post
    Annoyingly not on Audis...
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,781
    I bought an inline adapter from demon tweeks that allowed a 1/8 BSP thread. It depends on the size of the sensor though. Most decent ones will be 1/8 BSP or NPT. I think the inline mechanical style ones are the same.
    I went with an SPA dual boost and fuel pressure gauge but I've yet to install it. They're pretty much one of the best in the game so worth paying extra for. The loom and sensors are top notch (as is the gauge of course).
    Now that I've got an aftermarket fuel pressure regulator, the sensor can fit directly into that which is cool.
    With regards to the location, anywhere between the pump and fuel pressure regulator. So basically the feed line to the fuel rail on the drivers side of the car. Remember to use proper fuel line clamps and not jubilees.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    I'm looking at something along the lines if this-
    http://bit.ly/16tMTNS
    Not wanting any additional gauges within the cockpit if can be helped.
    How do you mean by fuel line clamps. Are the like jubilee clips but slightly different screw clamp design? Like this - http://bit.ly/18rYg3d
    2001 S3 (AMK)
  1. Opinions on Boost and Fuel Pressure Gauges - S3 8P
    By Boydie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th September 2011, 10:04
  2. ****Oil pressure gauge install with pics**** As requested...
    By ALPINE in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd April 2010, 19:48
  3. Fuel Pressure Regulator
    By imported_SYNAPS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th January 2005, 16:06
  4. Boost gauge install in S4
    By Olly__K in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th January 2005, 13:08
  5. Gauges Installed
    By Wak in forum TT/TT-S/TT-RS Forum
    Last Post: 22nd November 2004, 11:34
