Page 1 of 2 12 LastLast
Results 1 to 40 of 79
Like Tree26Likes
Thread: R-Tech stage 2 plus. Is my car ready?
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    Once I get my clutch replaced I'm looking for a custom map.
    Been in touch with r-tech and I think I'm close to the spec needed for the stage 2 plus.
    My two worry areas are.
    1 Bar plus actuator needed - I'm running standard K04 actuator which comfortably holds over one Barr. Is this sufficient? Or do I need one that holds 1 bar with n75 disconnected.
    Intercooler.
    I have a ah fabs v1 intercooler. If I upgrade the pipework to 2.5" will the core be up to the job?
    I'm aiming for 300bhp - turbo permitting.
    I have the WMI installed already and have Bosch 550's in their way over the pond to me.
    I'm hoping I'm close to spec needed.
    Westy likes this.
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Bills lupo runs the V1 core with 63mm pipework at 300hp... be fine
    <tuffty/>
    g60leigh likes this.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    Quote Originally Posted by ;1997181
    <tuffty/>
    That would be great if it would. I have WMI set up too so should be extra help. Never (yet) had any heat problems.
    2001 S3 (AMK)
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    Leigh what's your cara full spec? Similar to mine I think.
    Don't worry about the actuator too much as niki won't go above 21psi.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    Forge FMDV008 Recirculation Dump Valve
    Revo Stage 2 ECU Map
    Badger 5 V2 TIP with J&R Cone filter and Heat Shield
    TFSI Coil packs with NGK Iridium Spark Plugs
    Evap removal
    Miltek Cat back stainless steel exhaust
    AH Fabrications V1 front mount intercooler
    Relentless V2 tubular steel manifold
    Relentless V3 3” Down pipe and 200 cell sports catalytic converter
    Oil catch can and PCV removal
    Titanium manifold heat shield
    AEM 30-3000 Progressive WMI
    Running standard K04 but seems strong
    Just had timing belt. Water pump. Oil pump and pick up changed on last service (2weeks ago)
    Stage 3 paddle clutch coming soon.
    2001 S3 (AMK)
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    I'm gong off of the email I received from one of the guys at r-tech and that was on their requirement list for stage 2 plus.
    2001 S3 (AMK)
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    If you want an actuator.. BBT is the man. I only popped one on because mine was fubard! But just turned out it made everything better lol! Have you got a manifold? My injectors maxed out at 280bhp!
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    Quote Originally Posted by Gops View Post
    Relentless v2 exhaust mani.
    Standard inlet.
    Bosch 550's on way ready. Still need adaptors though.
    2001 S3 (AMK)
    Westy's Avatar
    Dec 2008
    17,283
    Same a mine Leigh except I have a decat. How's your fuel pump?
    S3 Build Thread
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    Fuel pump is fine as far as I know. Is there a way of testing?
    2001 S3 (AMK)
    Westy's Avatar
    Dec 2008
    17,283
    Quote Originally Posted by g60leigh View Post
    You can put a gauge on the fuel line to check. My pump was brand new but that is one o the big mods that people don't realise.
    I'm excited to see what yours can do.
    S3 Build Thread
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    Quote Originally Posted by Westy View Post
    Will look into that. Thanks for the heads up. May hit eBay to price one up.
    I'm excited myself for this. I'm running stage two revo now with a few adjustments on the SPS switch. But never been one to chase rolling road figures. So don't truly know what I'm at now.
    2001 S3 (AMK)
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    Do you know what pressure it should be running?
    Looking a fuel pressure gauges now lol.
    2001 S3 (AMK)
    Westy's Avatar
    Dec 2008
    17,283
    I can't remember but bill posted on a thread in the last 2 weeks advising someone of the pressure.
    S3 Build Thread
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    Found it.
    It should be 3 Barr + boost pressure and rise with boost.
    Westy likes this.
    2001 S3 (AMK)
    Scullies's Avatar
    Feb 2012
    Dubai
    1,260
    Be worth checking for boost leaks before the remap, in case there is something that is not as simple as just tightening up the clamp.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    Quote Originally Posted by Scullies View Post
    Given it a thorough visual after getting it back from timing belt. And holding boost with no drop off.
    Unfortunately I don't have access to a smoke tester. Would love to test with one of them.
    2001 S3 (AMK)
    Scullies's Avatar
    Feb 2012
    Dubai
    1,260
    I use a compressor hooked up to the TIP and squirt soapy water over joints and look out for bubbles. mcgyver mechanics 101
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    I've got a tester I can use similar to that. If I can adapt it to fit K04 tip.
    2001 S3 (AMK)
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    My pal has a smoke tester Leigh.... Manser motors over on the BonLea.... Behind the old Audi Garage...
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    Quote Originally Posted by cecilthesausage View Post
    You know how much he would charge to run a test Rob?
    2001 S3 (AMK)
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,542
    Id be inclined to get an uprated actuator from dan.
    Whilst it might not give bigger headline figures, not that youre chasing any, but power and torque will be sustained longer, that will be a big difference in performance from a car that hdas a weak stock one.
    Gops' results speak for themselves.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    How much of a job is it to fit on the S3? Is it a turbo off job or can it be done in situ?
    Thanks for all the pointers guys.
    2001 S3 (AMK)
    Jul 2010
    Teesside
    933
    I'm not sure.... Have a ride over and see him tell him I sent ye....
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    Lmao. Tell him Vinny sent ya.
    Got a few bits to change over first. Including the red turbo flexi ( thank you for that mate 😉 )
    2001 S3 (AMK)
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    20 mins max to change the actuator leigh..
    Charge pipe off, 2 nuts turbo side ...then the nut holding the rod on the wastegate, just may have to mess with the pre load to get it spot on (usually 3-4 turns from the wastegate been shut)
  28. #27
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    Cool
    Done in situ?
    2001 S3 (AMK)
  29. #28
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    yeah edited....above..
  30. #29
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    Sounds good. I like easy jobs.
    Westy likes this.
    2001 S3 (AMK)
  31. #30
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    Messaged Dan to see what he says about actuator.
    Toying with idea of changing intercooler pipework still.
    2001 S3 (AMK)
  32. #31
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,384
    I'd say an actuator is absolutely essential, for what it costs, and the figures you're hoping to get, it'd be madness not to do it given what we know now through the last 18 months of development.
    Also, if your fuel pump is original, it'll be highly likely to be a limiting factor IMO
  33. #32
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    I agree. The invaluable advice in here has put them firmly on my radar.
    Going to assess the fuel pressure with an inline gauge and then look at options for up rated fuel pump. I've seen a few options for FWD but not come across any for 4wd. Yet!
    2001 S3 (AMK)
  34. #33
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,384
    Problem is, with a fuel pressure gauge, it'll only be measuring whether it's keeping up NOW won't it? Not whether it'll keep up when most is asked of it, if you see what I mean?
    Fred saw very decent figures from his ko4 with a stock actuator, but on the whole it seems that power and torque are far easier to sustain with a decent actuator fitted, like on Gops car, it seemed to be the key to a sound result.
    Very good cars will still make the figures without clearly, but better to be prepared I'd say.
    Westy, Gops and StaceyS3 like this.
  35. #34
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    That's a very good point Mr Prawn.
    Fuel pump now added to the list. Any suggestions for updated options.
    Actuator will be changed. Just waiting for Dan to get back to me and one will be ordered.
    2001 S3 (AMK)
  36. #35
    Scullies's Avatar
    Feb 2012
    Dubai
    1,260
    that DA-31 seems to be a popular choice for you guys on that side of the world.
  37. #36
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    Is that an in tank replacement. ?
    Will search it out when I'm at home.
    2001 S3 (AMK)
  38. #37
    Westy's Avatar
    Dec 2008
    17,283
    No it's an inline one.
    S3 Build Thread
  39. #38
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    Will that be sufficient or do I need both upgrading?
    I really need to get chance to sit in front if computer and have a search. Can't find anything in tappatalk
    2001 S3 (AMK)
  40. #39
    Westy's Avatar
    Dec 2008
    17,283
    You really need to have a healthy in tank pump. The pump will support the power you want. If you then want more power you can add an inline.
    S3 Build Thread
  41. #40
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,391
    Just seem this is classifieds on here:
    http://www.audi-sport.net/vb/classifieds.php?do=viewitem&itemid=9155&urlid=2
    Might be if use.......... Someone in the know can tell you.
    Sean
    Current: 2013 Audi A3 2.0 tdi s line 8V in black SD nav+ extras, E46 BMW M3, 1971 Volvo p1800, 2014 Ford transit sport 155ps ;-)
    Previous : Focus st 225 stage 1 (265 bhp and too much torque), 2002 audi s3 bam engine completely OEM, 2001 Audi a3 1.8 TQS 221bhp and about 20 other cars, majority civics ek4/ek9 and Bmw / Audi soot chucker's!
  1. R-tech stage 2 remap
    By stevegti2 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2013, 18:54
  2. A4 1.8T Stage 3 - Owned the car 1 day and ive broke it already. HELP!
    By SilverSaloon in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th February 2013, 10:09
  3. car ready for winter.......
    By JimC64 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 20th December 2012, 10:20
  4. Booked in with R-Tech stage 2 map :)
    By Turboman-a3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd April 2011, 20:59
  5. Car ready for the summer thanks to Polished bliss
    By nicklght in forum Detailing
    Last Post: 8th April 2008, 22:35
