Badger5EM Tuning
Results 1 to 7 of 7
    Jun 2013
    Hampshire
    32
    Seat height adjust not working
    Evening all,
    The electric height adjust on my drivers seat has just stopped working.
    When switching it up and down there is a clunk - but the seat doesn't move.
    Is this common?
    I guess I'll have to take the seat out and investigate - is this just a case of unbolting the rails from the floor pan and the electrical plug?
    cheers
    Duncan
    Bigandbald's Avatar
    May 2013
    Basingstoke
    105
    Hi Duncan,
    if you do a search for rector not working or something similar there is a post on how to fix from memory
    `02 S3 AMK now sold, need more doors so along comes an '04 Seat LCR Bam 225, badger5 tip, s2000 filter, very high mileage now with badger5 remap @ 275.5bhp.
    Jun 2013
    Hampshire
    32
    Cheers, will do.
    Aug 2011
    Plymouth
    745
    Add Lavis89 on Facebook
    they're easy to whip out if you need to, take the trim off the back of the rails, cant remember how to get the inside trim off, i broke all the clips on mine :/
    outside trim has 1 screw in the middle which is covered by a cap then will pop out
    undo the 2 bolts at the front
    pop the seat back a bit
    you should have decent access to get to anything you need to now just by tilting the seat back, if you need it right out just disconnect the electrics (2 plugs) then shove the seat right back out of the rails and lift out
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave adjustable tie bars
    Soon to be done: SAI delete, Install the toyosport FMIC i have kicking about in my living room
    Apr 2013
    JHB, South Africa
    168
    I had the same problem with mine a few months back. There a tiny switch on the seat. Just needs to pressed to restet and the adjustment works again.
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    I've fixed mine - was a broken micro switch, they are about £20 to replace (complete rip off but no choice).
    IN terms of getting the seat out - have a look in here, tells you exactly what to do (and also how not to set the airbags off!)
    Audi A3/S3 Workshop Manuals
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Jun 2013
    Hampshire
    32
    Quote Originally Posted by Kuvi-S3 View Post
    Hi Kuvi,
    where was the switch?
    duncan
  1. Seat lumbar controls not working
    By mm707 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th January 2012, 11:42
  2. Electric Seat Height Adjustment.
    By fourcircle in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th December 2011, 13:07
  3. Drivers seat height adjustment - Problem
    By DaveA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th June 2011, 08:20
  4. S3 Electric Seat - Height Adjustment Not Working
    By imported_spuddie007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th May 2006, 22:02
  5. Seat height adjustment.
    By S3BeemerBeater in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th April 2004, 09:14
