Badger5Volks Autos
    Apr 2013
    12
    Help needed! 16396 fault code
    I checked for codes this afternoon and this came up
    i have a 51 a3 aum
    16396 - Bank 1 : Camshaft A (Intake): Advance Setpoint not Reached (Over-Retarded)
    P0012 - 35 - 10 - - - Intermittent
    I've heard it can be oil pressure related? But I have no idea, I took the sump off for a clean and changed the oil last week if this could be anything to do with it ? And I also have an erratic idle!
    Any help and advice would be a great help thanks
    mark_S3's Avatar
    Yorkshire & Humber Events Rep
    Sep 2012
    Wakefield
    600
    (Over-Retarded)
    Possible Symptoms:
    Erratic Idle
    Possible Causes:
    Intake Camshaft Adjuster tight/stuck
    Intake Camshaft Adjuster faulty
    Possible Solutions:
    Check Intake Camshaft Adjuster
    Use Output Test, Meas. Value Blocks (MVB) & Basic Setting
    ***2000 Audi S3 8L APY***
    * Milltek CATback * Milltek 200 Supercell Sports CAT * SuperChips SPS Stage 1 Remap * Forge 008p *
    * 18" Audi TT 240 Sports Alloys in Gunmetal Grey * Pagid Discs with BD Predator Pads *
    * Badger5 v2.2 TIP, JR Filter with Heatshield * N249 Delete * N112 Bypass *
    * PowerFlex ARB Bushes * TFSI Coilpacks * Saikuo Michi S3-OCC *
    * PowerFlex Rear Engine Mount Bushes *
    [IMG][/IMG]
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Does it keep returning after you've cleared it? I've seen this a few times on my car but it normall goes away when cleared.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Apr 2013
    12
    Yeah I cleared it and I will look in a couple of days to see if it comes back, but it's the first time I've seen this come up so I'll keep an eye on it
  1. 16396 fault code help
    By marty.blake7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2013, 20:58
  2. Need some help with a fault code please?
    By DaveA3-TDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th November 2011, 09:39
  3. I need some help with some fault codes please
    Last Post: 19th May 2011, 16:14
  4. Help needed with fault codes
    By j4jon in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th January 2008, 06:59
  5. Help with recorded fault code
    By Damian s in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th March 2007, 18:33
