Chris NottAH Fabrications
Results 1 to 15 of 15
    Oct 2013
    6
    location of 409 relay am i in the right place
    hi guys i have a 99 1.8t agu i have had a few issue's recently and i thought it might be the fuel pump relay on its road out , bought on and opened up the panel underneath the steering wheel expecting to just swap over the 409 but there is no 409 there am i in the right place.? there is a spare location in between 100 and 167i will try and include a pic with this,
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    401
    I can find out tomorrow mate when I'm at work buddy
    Oct 2013
    6
    cheers lee that would be magic just wondering if there was a diagram anywhere that would say what relay's should be where
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    401
    Are you sure 167 isn't the fuel pump relay bud that's its normal location I'm sure
    Oct 2013
    6
    just been on vagcat lee it says 167 is the "
    (10) 191906383C
    contact close relay / for fuel pump / relay location/code no.: / F >> 8L-W-999 000*
    4/167 /
    but it also says 409 is the "
    (10) 1J0906383B
    relay for fuel pump / relay location/code no.: / F 8L-X-000 001>>
    4/409 /
    is there a difference between the "relay for the fuel pump" and the "contact close relay/for fuel pump" or should i have both?
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    401
    I think you will have one or the other mate tbh I will double check this tomorrow for you buddy
    Oct 2013
    6
    cheers lee maybe ive bought the wrong one do you think i could replace the 167 with a 409 if it fits?
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    401
    Don't think so bud il get on to tps as well tomorrow bud
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,504
    Isn't 409 in the engine bay?
    Dec 2010
    17
    Most of the agu's have relay 167 instead of 409 number relay mate.
    167 is the fuel pump relay of a golf. I replaced that relay with a new one when I had fuel pump problems and it sorted it. 167 and 409 are the same relay
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    401
    I can also confirm 167 is the fuel pump relay mate
    Oct 2013
    6
    thanks guys i phoned audi and they said that it should be a 409 for my chassis number but the 409 seems to have more connectors on it will it be ok to put a 409 in? as thats the one i have
    Oct 2013
    6
    right guys just an update as it might help someone else i have changed the 167 for the 409 and took it for a spin , going alot better now so finger's crossed only time will tell i think ,i'll put in an update in a week
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    401
    Glad to hear it mate
    Nov 2013
    Hi guys, my car cut out the other day. Won't start now, its an '01 S3. I suspect its the Fuel Pump Relay as the fuel pump cannot be heard priming when ignition is turned on. When i removed the lower dash trim today i found the exact same positioning of the relays as the pictures above. So far this thread has answered a few of my questions (THANK YOU) as i had also expected to see a 409 relay, where the 167 currently sits. Could somebody just confirm for me, should my car have a 409 and should I go and get that part, replace it and then see what happens? its only a $30 part so cheap enough. Thanks in advance
  1. hi im new to this so dont know if thus is the right place to post
    By john glendinning in forum General Technical / How To
    Last Post: 21st April 2013, 16:12
  2. Few pointers please, is everything in the right place?
    By Lavis89 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th July 2012, 22:00
  3. Not sure if im posting in the right place..
    By rubbi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th August 2011, 15:33
  4. Replies: 11
    Last Post: 28th June 2006, 22:35
  5. Is this the right place?
    By caminator in forum Tuning
    Last Post: 26th May 2004, 16:06
