Volks AutosAH Fabrications
    May 2012
    RETFORD, NOTTS
    1,703
    Wind problem... driver door / window plus door closed sensor
    I know there was a thread recently, but i cant find it, and i tried the funky google search on asn only, and nothing.
    How do i fix this noise? it gets louder when i put pressure on the top of the window.
    Also the door close sensor is intermittent, where is this and it is an easy fix?
    Window reg is packed up too, i think i might need a complete door worth of parts lol
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Lewis583's Avatar
    Mar 2010
    829
    Are all the seals on the door ok? Check that the door sits properly when closed (compare with the other side).
    The window glass and frame is fitted with wedges that adjust how the window sits, these may need tweaking slightly to bring the top of the window and frame inwards and hence putting a little more pressure on the seals. The door card needs removing to adjust the wedges. Has the window/frame been off the car recently or messed with?
    I'm pretty sure that the door status contact switch is built into the door lock on these, but I'm not 100% on that. Maybe someone more up on the MK4 chassis can confirm? If that is the case I would try and spray some WD40 into the door look to disperse any moisture that may be sitting in there.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    May 2012
    RETFORD, NOTTS
    1,703
    the wind noise has been there for ever, the regulator recently screwed up and needs fixing though. the door switch has been intermittant since owning the car, but more noticiable now.
    Lewis583's Avatar
    Mar 2010
    829
    Try the above and report back.
    Full VCDS
  1. drivers door window
    By Pete N Kelly Mileham in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th July 2012, 21:03
  2. Drivers door window winder problem
    By T0m in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th August 2011, 11:14
  3. A3 door/window problem. Help!!!!
    By bjamieson in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th February 2009, 16:18
  4. PROBLEM WITH DOOR OPEN/CLOSED SENSOR
    By stuart.garlinge in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th January 2009, 19:40
  5. Drivers door window regulator broken - advice please
    By bebecheekymonkey in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th January 2009, 23:53
