EM TuningAH Fabrications
Results 1 to 8 of 8
Thread: Fault Code
    Oct 2013
    48
    Fault Code
    01262-Turbocharger (TC) wastegate regulating valve Wiring, fuse, TC wastegate regulating valve
    I have noticed at times that the recirculation valve has been fluttering and also sometimes it feels as if all boost has been lost intermittently and then returns a few minutes after.
    I had my suspicions that the recirculation valve needs replacing, would this error code and symptoms confirm this?
    Your help is appreciated.
    Kind regards.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,527
    Your N75 valve may be faulty. Check the wiring to the N75, and the pipes going out!
    rayh77's Avatar
    Purple Merlin
    Feb 2013
    19
    Read up on N75 bypass, worth a read , threads are on forum
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Quote Originally Posted by rayh77 View Post
    No such thing mate... you are thinking of the N249 bypass... N75 is the boost control valve... N249 is the ECU's control over dumping boost via the DV... different beasties...
    <tuffty/>
    ShaunS3's Avatar
    Yorkshire & Humber Rep.
    Mar 2012
    West Yorkshire
    823
    Quote Originally Posted by ;1995241
    <tuffty/>
    How do you know if an N249 bypass has been done correctly?
    Oct 2013
    48
    So would anyone here have first hand feedback on the N75 J valve as a replacement?
    The car is a 1998 150. Its completely stock at the moment but I have plans to tinker with the engine to quite an extent over the next few months.
    Would the J valve be suitable for this?
    Oct 2013
    48
    Anyone?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Quote Originally Posted by neap38 View Post
    Personally... wouldn't touch it with a barge pole... AGU's are more tolerant but it still produces a boost spike and boost spikes are bad...
    <tuffty/>
  1. S6 Fault codes
    By bigmoose in forum General Technical / How To
    Last Post: 16th June 2005, 16:16
  2. Help: Fault code 16795
    By imported_rustys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2005, 17:17
  3. information on fault codes
    By vwjin in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2004, 00:45
  4. Fault Code
    By gman in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2004, 16:44
  5. fault code
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2003, 14:05
