AH FabricationsEM Tuning
Results 1 to 9 of 9
    Oct 2013
    newquay
    45
    will the clutch kit be suitable
    Hi all will this clutch kit be ok for my 2002 a3 tqs ebay item number 110951762121
    Cheers jon
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    It says "6 speed models" so i'd imagine no.
    I wasnt aware they did 6 speed cars with those engines though.
    TD5 Land Rover Defender build
    Oct 2013
    newquay
    45
    my engine code is ary ive contacted the seller and they say it fits. just want to make sure.
    seems like a good price and its only going in a daily driver.
    Cheers jon
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    If its an 02M five speed box then it should fit...
    <tuffty/>
    Oct 2013
    newquay
    45
    my car uses a six speed box. so I take it that this will not fit.
    any links to what would work been told s3 clutch a fly wheels work. would just like someone to help make sure I get the right one as I want to keep the cost down when it goes to the garage. any help/advise greatly received.
    Cheers jon
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    6-speed is 02M too... they did a five speed version on the quattros fitted to some TT 180's and A3 TQS... anything quattro got an 02M box
    <tuffty/>
    Oct 2013
    newquay
    45
    ok I see any Quattro 02m box but some were 5 speed and some were 6 speed. if it for the 6 speed then it will fit??
    Cheers jon
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Have you tried sensing the seller a msg asking the question quoting your model/engine code? worth doing as if you buy it and there is a problem you may have no come back as its listed for a differnt car...
    <tuffty/>
    Oct 2013
    newquay
    45
    have done this tuffty and seller says that if there is a problem then they will take a return at there cost. so will probably go for it. thanks for all help.
    cheers jon
  1. Will this Clutch kit fit my 8L 1.8T?
    By gniknotle in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th April 2012, 05:23
  2. Fitting the keyess kit from vagparts - help!
    By imported_bpascua in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th July 2004, 11:50
  3. grip force heavy duty clutch kit
    By dann959 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th June 2004, 04:44
  4. WILL THE S3 RECARO SEATs FIT STR8 INTO A3 1.8T 2WD
    By lakhan in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2004, 01:49
  5. where will the creaks end? Bain of my life
    By dandy in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2003, 08:25
