EM TuningVolks Autos
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,277
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Dying Xenon bulb, faultyballast or both?
    Hi guys,
    Now I've already had a search for this issue....however it seems as though just about every dying Xenon bulb ends up going a pink or yellowish kind of colour rather than the the blueish colour mines now omitting.
    Over the past couple of weeks it's been getting more frustrating to get the passenger xenon bulb to fire up first time...I would often have to turn them to side lights and onto dipped beam quickly for it to work. (makes me think ballast is fecked)
    Now the past few day when the passenger bulb does turn on, it's an obvious light blue colour - which is pretty cool...BUT not when it doesn't match the other side and doesn't even omit that much light
    So my question is....do I need to change just the xenon bulbs?
    Or will the passenger bulb still be a slightly blue colour in comparison to the drivers side with two new bulbs and the same ballasts?
    Chris
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    Well, I recently had a new headlight and it was fitted with new bulbs etc and now I notice the other headlight bulb is a lot more yellow than the new one, and because I'm anal I need to change it. Therefore, I would suggest you replace both at the same time.
    P.S rare to see a pre-facelift noggy. Not seen that before.
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,277
    Cheers for the quick and speedy reply....
    Yeah I have noticed whilst trawling though the threads you've changed the whole unit. You must have some serious love to spend that sort of dosh on your motor
    Yeah not alot of pre-facelift noggys about....the order book I got when I purchased the car doesn't even have it as a colour option
    So I think new bulbs will need to be ordered for a quick fix....now where's that pixie to help change them
    2000 S3 APY
    Jun 2011
    Wellingborough
    1,170
    Its the Bulb Chris.
    Can supply for you when you order.
    Trups
    SLOW REPLIES BETWEEN 22nd - 30th June due to been out the office, please bare with me. Thanks
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,277
    Quote Originally Posted by t8ups View Post
    Its the Bulb Chris.
    Trups
    Cheers Trups,
    I'll drop you a PM
    2000 S3 APY
  1. Both Xenon Bulb Failure - ?
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st October 2009, 21:50
  2. Xenon Bulbs
    By joe6886 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2008, 12:55
  3. Looking to replace my non Xenon bulbs...
    By kevlar in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th January 2007, 22:07
  4. different xenon bulbs?
    By 08080808 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2006, 20:14
  5. xenon bulbs
    By chippie in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th October 2003, 21:21
