EM TuningVolks Autos
Results 1 to 8 of 8
    Apr 2013
    Dumfries and Galloway
    38
    Car wouldn,t go into first gear
    Hey guys, i was sitting at some traffic lights today with the car in neutral. The lights went green and when i tried to put it in first it just wouldn,t go in. I had to pull it back into second, then go forward in one stroke for it to go in. Does anyone know what could be causing this?
    It is a 1.8t sport 2001 AUM. 108k
    Dave
    Apr 2013
    38
    anyone?
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    Could be the gear selector.... Take it to a gear box specialist... I've had the same problem before... Cost me about 40 quid to get it fixed... That was on a A3 1.8.... Long time ago though... Don't know how much it would cost now...
    Nov 2012
    Kent
    451
    Add Tim_Attard on Facebook
    have a look at the hear linkeage bit (sorry dont know the name) its between the engine block and air box and see if anything is obstructing it etc, i had this because i fitted my catch can too low and was hitting the bottom of it when it tried to go into 1st. unlikley to be your problem but worth a check.
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/187166-tims-max-power-a3.html
    Quote Originally Posted by 16Klappe View Post
    Don't listen to him Tim, You're my hero, I'm proud of you.
    Apr 2013
    38
    Cheers guys, i,ll check that out, it did it again twice at some traffic lights, goes straight in if i throw it from 2nd straight into 1st
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    265
    Clutch drag? Slave not fully lifting clutch off flywheel? but would assume it'll do that in all gears ??
    Apr 2013
    38
    I have thought that too, all other gears seem fine tho. Struggled to get it into reverse the other day actually, thats only happened once.
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    265
    I'd check your gearbox oil level. Might explain why 1st is so hard to get into as that'll b quite worn, synchro won't appreciate low oil
  1. Bearing noise when setting off in first gear is it my turbo?
    By Dj Vegas in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th November 2011, 11:58
  2. Car judders and difficult to put in first gear (not all the time)
    By danonline in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2011, 21:30
  3. Car wouldn't start
    By batwad in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2006, 21:27
  4. Lumpy in First gear??
    By Blakeypj in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2006, 22:16
  5. Crunch going into third gear?
    By S3K in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2005, 17:36
