Monster MotorsportBadger5
Results 1 to 7 of 7
    rayh77's Avatar
    S3 AMK Merlin Purple
    Feb 2013
    Wales
    20
    ESP 4 w ESP Lateral Acceleration Fault
    Alright folks, got ESP light on constantly and lateral acceleration fault code (01423) Rears don't seem to be kicking in when losing grip, just fronts spinning, any yodas got any ideas or had same problems ?
    Any inputs appreciated
    Jul 2013
    Sussex
    41
    hi ive got the same problem but mines the longitudinal sensor abs and traction control lights come on but not every day. this sensor I think is only available from audi about £120 I think.
    A3 TQS
    Jul 2013
    Devon
    173
    Was £165 a couple months back or £150 if you can get it trade from tps, or if your handy with a soldering iron you could have a go at fixing it, you could also try resetting it first with vcds.
    Bit more info here
    The Audi TT Forum :: View topic - "How to" Reset Long/Lat Sensors (G200/G251 or G419?)
    Querbeschleunigungssensor G200
    rayh77's Avatar
    Feb 2013
    Wales
    20
    Cheers for the replies fellas, S3ben, seen a few on EBay, but recon might have a look inside see if anything's fixable but probs buy a new one, Rupe, cheers for link, need full version of Vagcom which gonna get next couple of days so can try the reset, as when I checked channel 004 the other day, the reading is showing 7 degrees, and that's with the steering wheel straight! recon someone's ad the rack off or something at some point... 006 was asking though, so good chance the sensors goosed... although hoping reset will sort it!
    rayh77's Avatar
    Feb 2013
    Wales
    20
    That meant to say 006 was sound though
    A3 TQS
    Jul 2013
    Devon
    173
    When mine was playing up and I monitored it with vcds, it appeared to be stuck on one reading, I couldn't get the readings to fluctuate at all, after fitting a new sensor and resetting it to 0.0 as per that guide, I could bounce myself around in the seat and watch it fluctuate from around 0.0 - 0.1 etc. They fail quite often so a second hand sensor unless it was really really cheap I think would just be throwing money away.
    I did take my old sensor apart as per that other guide and re-soldered the chip, so have that as a spare now in case I do need it in the future.
    rayh77's Avatar
    Feb 2013
    Wales
    20
    The readings on mine are changing when moving the wheel, so although it's a long shot, recon prev owner might of changed the sensor but not reset on Vagcom, well that's what am hoping anyway.. if not I'll bite the bullet and buy a new one.
    Cheers again m8
  1. Lateral Acceleration Sensor G200 -ESP Problem fixed :D
    By S3_DAVE in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th November 2012, 19:14
  2. ESP and flashing glow plug icon. Lateral acceleration sensor?
    By Taff D in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2012, 18:52
  3. Replies: 10
    Last Post: 12th April 2012, 06:44
  4. Replies: 4
    Last Post: 24th March 2012, 18:24
  5. ABS and ESP lights - Brake pressure sensor fault - Help!
    By wilkoa6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th March 2010, 15:45
