Sky InsuranceVolks Autos
    Jul 2013
    Sussex
    41
    Exclamation temp and fuel gauge.
    Hi my temp and fuel gauges are offset. ive been quoted £125 +postage to have this fixed. But has anyone fixed this diy??? is it even possible to fix at home.
    May 2012
    RETFORD, NOTTS
    1,753
    Depends on the make of clocks but usually it's a chip failing on the board. If you wanted to replace them like for like like may be able able to do this through the post. Unfortunately I'm not good enough with the soldering iron to repair them yet though. I think. You could get a replacement clocks for approx 40£ and fit them yourself though. Depending on the year I could read your pin if you send me the new clocks and using vcds you could program them in.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. Fitting an oil pressure / oil temp and boost gauge...
    By JonBoi21 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2013, 00:14
  2. Audi S3 EVAP and fuel gauge readings
    By mmalh0151 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th February 2013, 11:51
  3. speedo stopped working and fuel gauge going crazing!
    By S3 JOHN in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2012, 19:51
  4. my temp and diesel gauge arnt working help me...
    By deemci3 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th September 2011, 23:08
  5. Airbag light and Fuel Gauge FAULT!!!
    By jetturk in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th November 2010, 08:31
