Hi my temp and fuel gauges are offset. ive been quoted £125 +postage to have this fixed. But has anyone fixed this diy??? is it even possible to fix at home.
Depends on the make of clocks but usually it's a chip failing on the board. If you wanted to replace them like for like like may be able able to do this through the post. Unfortunately I'm not good enough with the soldering iron to repair them yet though. I think. You could get a replacement clocks for approx 40£ and fit them yourself though. Depending on the year I could read your pin if you send me the new clocks and using vcds you could program them in.
