Sky InsuranceAH Fabrications
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    265
    how to set engine cam timing
    Hello
    wanting to know how to set the engines cam timing as ive now fully stripped down the block for it`s re build but need to know how to set the cam timing up as i dont think its a case of crank at TDC and cam at TDC and away you go??
    Dont wanna get the timing 180 out
    Im having a guess here but would it be cyclinder 1 at TDC then with head off rotate the cam pulley till cyclinder 1 vlaves start the intake cycle and set to TDC around that cycle and your done?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    There are timing marks... cam pulley has a mark that corresponds with a mark on the cam cover or if the cover is off then the exhaust cam sprocket (gearbox end) has a slot that aligns with a little arrow on the cam cap... there is also cam to cam timing to consider if you have removed the cams at anypoint too... if just refitting head and doing cam belt then Cyl 1 at TDC and exhaust cam at the timing marks mentioned above and all will be good
    <tuffty/>
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    265
    Thought it was that simple lol
  1. Replies: 2
    Last Post: 11th March 2013, 21:07
  2. Torque setting for cam cover bolts?
    By ButcherV6 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2010, 14:24
  3. A3 1.6TDI SPORTBACK - HOW IS THE ENGINE ??
    By shilts in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th February 2010, 00:05
  4. S3 Engine / Cams
    By wazza in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th February 2008, 17:16
  5. Dealer replacement: which engine this time?
    By mrmacmusic in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st November 2007, 23:13
